Configuring Measuring Component Sets
This portal is used to display and maintain measuring component sets.
Refer to Understanding Measuring Component Sets for more information.
You can access the portal by selecting Admin, then Aggregation, Measuring Component Set.
- Measuring Component Set: This zone displays details of a selected measuring component set.
- Dimensions: This zone lists the dimensions used to identify the attributes by which the aggregation should be analyzed. Note: Data in this zone is edited by clicking the Edit button in the Measuring Component Zone.
- Criteria: This zone lists the criteria that limits the data to be aggregated through a series of inclusions, exclusions, or both. Note: Data in this zone is edited by clicking the Edit button in the Measuring Component Zone.
- Individually Managed Items: This zone lists the criteria used to identify specific customers that should be aggregated in isolation from all other data that matches the dimensions and criteria defined for the measuring component set. Note: Data in this zone is edited by clicking the Edit button in the Measuring Component Zone.
- Measuring Component Set Participants: This zone displays the measuring components that are in the Measuring Component Set Participant table for the measuring component set. For each measuring component, this zone displays the most recent and last measurement date/times.
