Maintaining Asset Locations
You use the Asset Location portal is used to search for asset locations.
You can access the Asset Location portal from Menu > Asset Management > Asset Location. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the Service Point portal to view and maintain the selected record.
Note: In Oracle Utilities Customer To Meter, asset locations are created and/or updated when a service point is created and/or updated. If the service point has a contact associated with it, a corresponding contact will be created for the asset location. See About Contacts and Maintaining Contacts for more information about creating and maintaining contacts used with asset locations.
