Setting Up and Executing Customer and Premise Data Extracts
Setting up master data extracts involves the following steps:
Add audit algorithms on the Service Agreement, Account,
Person, MDM Service Point, Install Event, and Device maintenance objects.
Add the Generic Change Data Capture algorithm as an
audit algorithm on the Service Agreement, MDM Service Point, and Install
Event maintenance objects.
Add the Account Change Data Capture (SA-Based) - Include
Reactivated SAs algorithm as an audit algorithm on the Account maintenance
object.
Add the Person Change Data Capture (SA-Based) - Include
Reactivated SAs algorithm as an audit algorithm on the Person maintenance
object.
Add the Device Change Data Capture (Install Event-Based)
algorithm as an audit algorithm on the Device maintenance object.
Add the DataConnect synchronization request business objects
as Sync Request BO options on the Service Agreement, Service Point
and Install Event maintenance objects.
Execute initial load batch processes related to service
agreements, service points and install events.
Once the initial load synchronization has been executed,
changes to service agreements, accounts, persons, service points,
install events or related devices will trigger the creation of new
synchronization requests and resulting extraction files.
Execute the sync request monitor process.
Execute the extract batch processes related to service
