Country
Use the country codes to specify the countries in which your utility operates. You can specify one or more countries.
The country US, and all associated states, are delivered with the solution.
The table below provides additional details on the tasks you need to complete.
| Task | Configuration | Comments |
| Add all needed country records |
POST /api/CXIPlatformService/v1/CXIReferenceEntity/country Example: POST https://<hostname>/api/CXIPlatformService/v1/CXIReferenceEntity/country
Oracle recommends using the same value for 'id' and 'faValue' in the request. Multiple country records can be added together by adding them to the "items" list in the request. |
| Edit a country record |
POST /CXIPlatformService/v1/CXIReferenceEntity/country Example: POST https://<hostname>/api/CXIPlatformService/v1/CXIReferenceEntity/country
Multiple country records can be added at the same time by adding them to the "items" list in the request. |
| Delete a country record |
Multiple country records can be deleted at the same time by adding them to the "items" list in the request. |
| Fetch country records |
GET /utilitiesAdmin/v1/country Example: GET https://<hostname>/api/utilitiesAdmin/v1/country
A specific country record can be fetched using: GET /utilitiesAdmin/v1/country/{id} Example: GET https://<hostname>/api/utilitiesAdmin/v1/country/US |
Parent topic: View, Edit and Add Reference Types
