State
Use the state codes to specify the states in which your utility operates. You can specify one or more states as children of the country the belong to.
The table below provides additional details on the tasks you need to complete.
| Task | Configuration | Comment |
| Add all needed state records |
POST /api/CXIPlatformService/v1/CXIReferenceEntity/country/{id}/child/state Here, {id} is the country to which states should be added. Example: POST https://<hostname>/api/CXIPlatformService/v1/CXIReferenceEntity/country/US/child/state
Oracle recommends using the same value for 'id' and ‘faValue' in the request. |
| Edit a state record |
POST /CXIPlatformService/v1/CXIReferenceEntity/country/{id}/child/state Here, {id} is the country associated with the state you are editing. Example: POST https://<hostname>/api/CXIPlatformService/v1/CXIReferenceEntity/country/US/child/state
Multiple state records can be edited together by adding them to the “items” list in the request. |
| Delete a state record |
POST /CXIPlatformService/v1/CXIReferenceEntity/country/{id}/child/state Here, {id} is the country associated with the state you are deleting. Example: POST https://<hostname>/api/CXIPlatformService/v1/CXIReferenceEntity/country/US/child/state
Multiple state records can be deleted together by adding them to the “items” list in the request. |
| Fetch state records |
GET /utilitiesAdmin/v1/country/{id}/child/state Here {id} is the id of country associated with the states being fetched. Example: GET https://<hostname>/api/utilitiesAdmin/v1/country/US/child/state
A specific state record can be fetched using: GET /utilitiesAdmin/v1/country/{id}/child/state/{childid} Example: GET https://<hostname>/api/utilitiesAdmin/v1/country/US/child/state/Alabama |
Parent topic: View, Edit and Add Reference Types
