Insight Severity
The following insight severity records are delivered with the solution. You can modify these values or add new values as needed, using the information below. All records are delivered inactive.
You can now manage insight severity records using the information below, or using the Functional Setup Manager interface. See Manage Insight Severity with Functional Setup Manager for additional information.| Severity | Default Style | Active | Description | Rank | ID |
| F1IN | info | false | Information | 30 | F1IN |
| F1WN | warning | false | Warning | 20 | F1WN |
| F1ER | error | false | Critical | 10 | F1ER |
This table provides additional details on the tasks you can complete.
Be aware thatdescription is a translatable field, so the description values should be maintained in the relevant lookup code created under the lookup type ORA_UER_ INSIGHT_ SEVERITY if your implementation requires more than one language.
| Task | Configuration |
| Fetch insight severity |
GET /utilitiesAdmin/v1/insightSeverity Example: GET https://<hostname>/api/utilitiesAdmin/v1/insightSeverity A specific insight severity can be fetched using: GET /utilitiesAdmin/v1/insightSeverity/{id} Example: GET https://<hostname>/api/utilitiesAdmin/v1/insightSeverity/F1IN |
| Edit insight severity |
POST /CXIPlatformService/v1/CXIReferenceEntity/insightSeverity Example: POST https://<hostname>/api/CXIPlatformService/v1/CXIReferenceEntity/insightSeverity
You can also update multiple records in the same request. Example:
| Create new insight severity |
You can create multiple records in the same request. Example:
Parent topic: View, Edit and Add Reference Types
