Import Initial Account Data
Before you can begin using Customer Experience for Utilities solutions, you must perform the initial load of account data into the Oracle Fusion system.
This image shows a simplified example of what your file might look like when you complete this step:
Figure 5-2 Import Account Sample File
This image shows an example of the import account file.
  1. Using the method of your choice, export the following data from your Oracle Utilities customer information system (CIS) into a CSV file:
    • Person records with PER_OR_BUS_FLG = B
    If you are using Oracle Utilities Customer Cloud Service, release 24 or later, you can use batch processes provided in the system to export your data. See Exporting Data from Customer Cloud Service.
  2. Update the CSV file so that it contains the following column headings, in this order, and that the data in the columns represents valid Oracle Fusion values. For additional information about accepted values, see Appendix A: Data Mapping.
    1. OraganizationName - This column should contain the name of the business.
    2. SourceSystem - This column should contain the value CIS for all records.
    3. SourceSystemReferenceValue - This column should contain the Person ID from your CIS. For example, 0123456789.
    4. PartyNumber - If you are not using auto numbering, this column should contain the values that you want to use. You might use a combination of the SourceSystem column and the SourceSystemReferenceValue column, separated by an underscore. For example, this column might contain CIS_0123456789.
      Oracle Fusion has a Profile Option Code, HZ_GENERATE_PARTY_NUMBER, that controls whether the Party Number (Registry Id) is auto generated or provided. It also controls whether edits to this value are allowed. See How Do I Autogenerate Party Numbers?.
    5. Type - This column should contain the value that you want to use for the ZCA_CONTACT_TYPE of your organization party records. Valid lookup values are:
      • ZCA_CUSTOMER
      • ZCA_PROSPECT
      The default value can be set in Oracle Fusion and the field is typically hidden from users so they can't change the value after it is set. See How Do I Set the Default Account Type?.
      f you use ZCA_CUSTOMER or ZCA_CONTACT, addresses are not required because person addresses are not included in the data synchronization from your Oracle Utilities system. However, you must set the value for these profile option codes to No, so that the address is not required:
      • ZCA_ACCOUNT_ADDRESS_REQUIRED_ENABLED
      • ZCA_CONTACT_ADDRESS_REQUIRED_ENABLED
      See How Do I Set Up Required Address Option for Accounts and Contacts.
    6. You might also have additional columns to import characteristics. When importing characteristics, you must ensure that the column heading is an accepted value in the Oracle Fusion system.
    7. Import your file into Oracle Fusion. See How do I import and export files? for instructions.
    8. Verify that the accounts exist in the Oracle Fusion system.
