Insight Type User Actions
The following insight type user actions are delivered with the solution. Review the values to determine if you have the values needed for your implementation. You can modify these values or add new values as needed, using the APIs.
As noted in the table below, the Account 360 collections insights user action to view account debt (ACTION_VIEW_COLL_PROC) should not be enabled to display the Debt Summary drawer unless your Oracle Utilities CIS meets specific versioning requirements, as described in My Oracle Support Document 2876281.1.
| User Action | Entity Type | ID | Insight Type |
| ACTION_VIEW_BILL_ACC_DET | BillingAccount | C1ACCTPASTDUE_VIEW_BA_DET | C1-ACCT-PASTDUE-CARD |
| ACTION_VIEW_BILL_ACC_DET | BillingAccount | C1PERNONPAYCARD_VIEW_BA_DET | C1-PER-NONPAY-CARD |
| ACTION_VIEW_BILL_ACC_DET | BillingAccount | C1XA_C1INACTIVEACCTCARD | C1-INACTIVE-ACCT-CARD |
| ACTION_VIEW_COLL_PROC | CollectionProcess |
C1XCCOLLCARD_VIEW_COLL_PROC See note above regarding versioning requirements. |
C1-ACCT-COLL-CARD |
| ACTION_VIEW_OD_PROC | OverdueProcess | C1XCCOLLCARD_VIEW_OD_PROC | C1-ACCT-COLL-CARD |
| ACTION_VIEW_PAY_AGREE | PaymentAgreement | C1XCPAYAGREE_VIEW_PA | C1-ACCT-PAYAGREE-CARD |
| ACTION_VIEW_SA | ServiceAgreement | C1XCPAYAGREE_VIEW_SA | C1-ACCT-PAYAGREE-CARD |
| ACTION_VIEW_CUT_PROC | CutProcess | C1XCSEVCARD_VIEW_CUT_PROC | C1-ACCT-SEV-CARD |
| ACTION_VIEW_SEV_PROC | SeveranceProcess | C1XCSEVCARD_VIEW_SEV_PROC | C1-ACCT-SEV-CARD |
| ACTION_VIEW_COLL_PROC | Organization |
C1PERCOLLCARD_VIEW_COLL_PROC See note above regarding versioning requirements. |
C1-PER-COLL-CARD |
| ACTION_VIEW_COLL_SR | Organization | C1PERCOLLCARD_VIEW_COLL_SR | C1-PER-COLL-CARD |
| ACTION_VIEW_BUDG_ENRL_DET | BillingAccount | C1ACCTBUDGENRL_VIEW_BA_DET | C1-BUDGENRL-LIST |
| ACTION_VIEW_EBILL_ENR_DET | BillingAccount | C1ACCTEBILLENRL_VIEW_BA_DET | C1-EBILLENRL-LIST |
| ACTION_VIEW_APAY_ENRL_DET | BillingAccount | C1ACCTAPAYENRL_VIEW_BA_DET | C1-APAYENRL-LIST |
This table provides additional details on the tasks you can complete:
| Task | Configuration |
| Fetch insight type user action |
GET /utilitiesAdmin/v1/insightTypeUserAction Example: GET https://<hostname>/api/utilitiesAdmin/v1/insightTypeUserAction A specific insight type can be fetched using: GET /utilitiesAdmin/v1/insightTypeUserAction/{id} Example: GET https://<hostname>/api/utilitiesAdmin/v1/insightTypeUserAction/C1ACCTPASTDUE_VIEW_BA_DET |
| Edit insight type user action |
POST /CXIPlatformService/v1/CXIReferenceEntity/insightTypeUserAction Example: POST https://<hostname>/api/CXIPlatformService/v1/CXIReferenceEntity/insightTypeUserAction Sample body:
This payload can have one or multiple items, as needed. |
| Create insight type user action |
Parent topic: View, Edit and Add Reference Types
