User Actions
The following user actions are delivered with the solution. Review the values to determine whether you have the user actions you need for your implementation. You can modify these values or add new values as needed using the APIs. All user actions are delivered as inactive.
| ID | Active | Description | Rank |
| ACTION_VIEW_BILL_ACC_DET | false | Navigate to Billing tab in Account 360. | 10 |
| ACTION_VIEW_OPTY | false | Navigate to Opportunity Detail page in Oracle Fusion. | 10 |
| ACTION_VIEW_COLL_PROC | false | Navigate to the collection process. | 10 |
| ACTION_VIEW_CUT_PROC | false | Navigate to the cut process. | 10 |
| ACTION_VIEW_OD_PROC | false | Navigate to the overdue process. | 10 |
| ACTION_VIEW_PAY_AGREE | false | Navigate to the payment agreement. | 10 |
| ACTION_VIEW_SA | false | Navigate to the service agreement. | 10 |
| ACTION_VIEW_SEV_PROC | false | Navigate to the severance process. | 10 |
| ACTION_VIEW_BUDG_ENRL_DET | true | Navigate to drawer for enrollment in budget billing. (ORA_UER_ACT_BUDG_ENRL_DESC) | 10 |
| ACTION_VIEW_EBILL_ENRL_DET | true | Navigate to drawer for enrollment in E-bill. (ORA_UER_ACT_EBILL_ENRL_DESC) | 10 |
| ACTION_VIEW_COLL_SR | false | Navigate to collections service requests. | 20 |
| ACTION_VIEW_APAY_ENRL_DET | true | Navigate to drawer for enrollment in auto pay. (ORA_UER_ACT_AUTOPAY_ENRL_DESC) | 10 |
This table provides additional details on the tasks you can complete.
Be aware thatdescription is a translatable field, so the description values should be maintained in the relevant lookup code created under the lookup type ORA_UER_USER_ACTION_DESC if your implementation requires more than one language.
| Task | Configuration |
| Fetch user action |
GET /utilitiesAdmin/v1/userAction Example: GET https://<hostname>/api/utilitiesAdmin/v1/userAction A specific insight type can be fetched using: GET /utilitiesAdmin/v1/userAction/{id} Example: GET https://<hostname>/api/utilitiesAdmin/v1/userAction/ACTION_VIEW_BILL_ACC_DET |
| Activate user action |
POST /CXIPlatformService/v1/CXIReferenceEntity/userAction Example: POST https://<hostname>/api/CXIPlatformService/v1/CXIReferenceEntity/userAction Sample body:
This payload can have one or multiple items, as needed. |
| Edit user action |
PATCH /CXIPlatformService/v1/CXIReferenceEntity/userAction Example: PATCH https://<hostname>/api/CXIPlatformService/v1/CXIReferenceEntity/userAction Sample body:
| Create new user action |
Parent topic: View, Edit and Add Reference Types
