Insight Group Insight Types
The following insight group insight types are delivered with the solution. You can modify these values or add new values as needed, using the information below. All records are delivered inactive.
You can now manage insight group insight type records using the information below, or using the Functional Setup Manager interface. See Manage Insight Group Insight Types with Functional Setup Manager for additional information.| insightGroup | ID | insightType |
| C1XP | C1XP_C1PERNONPAYCARD | C1-PER-NONPAY-CARD |
| C1XA | C1XA_C1ACCTPASTDUECARD | C1-ACCT-PASTDUE-CARD |
| C1XC | C1XC_C1COLLCARD | C1-ACCT-COLL-CARD |
| C1XC | C1XC_C1PAYAGREECARD | C1-ACCT-PAYAGREE-CARD |
| C1XC | C1XC_C1SEVCARD | C1-ACCT-SEV-CARD |
| C1XA | C1XA_CONTRACT_RENEWAL | CONTRACT_RENEWAL |
| C1XP | C1XP_CONTRACT_RENEWAL | CONTRACT_RENEWAL |
| C1XA | C1XA_C1INACTIVEACCTCARD | C1-INACTIVE-ACCT-CARD |
| C1XP | C1XP_C1-PER-COLL-CARD | C1-PER-COLL-CARD |
| C1XA | C1XA_C1-ACCT-COLL-CARD | C1-ACCT-COLL-CARD |
| C1PE | C1PE_C1APAYENRLLIST | C1-APAYENRL-LIST |
| C1PE | C1PE_C1BUDGENRLLIST | C1-BUDGENRL-LIST |
| C1PE | C1PE_C1EBILLENRLLIST | C1-EBILLENRL-LIST |
| C1PE | C1PE_C1PBILLENRLLIST | C1-PBILLENRL-LIST |
| C1PE | C1PE_C1WEBENRLLIST | C1-WEBENRL-LIST |
This table provides additional details on the tasks you can complete:
| Task | Configuration |
| Fetch insight grouping |
GET /utilitiesAdmin/v1/insightGroupInsightTypes Example: GET https://<hostname>/api/utilitiesAdmin/v1/insightGroupInsightTypes A specific insight type can be fetched using: GET /utilitiesAdmin/v1/insightGroupInsightTypes/{id} Example: GET https://<hostname>/api/utilitiesAdmin/v1/insightGroupInsightTypes/C1XP_C1PERNONPAYCARD |
| Edit insight grouping |
POST /CXIPlatformService/v1/CXIReferenceEntity/insightGroupInsightTypes Example: POST https://<hostname>/api/CXIPlatformService/v1/CXIReferenceEntity/insightGroupInsightTypes
| Create insight grouping |
Parent topic: View, Edit and Add Reference Types
