Insight Groups
You can now manage insight group records using the information below, or using the Functional Setup Manager interface. See Manage Insight Groups with Functional Setup Manager for additional information.| Description | ID |
| Billing accounts insight | C1XA |
| Business insights | C1XP |
| Customer Dashboard Agent Insights | C1XC |
| Program Enrollment Insights | C1PE |
This table provides additional details on the tasks you can complete.
Be aware thatdescription is a translatable field, so the description values should be maintained in the relevant lookup code created under the lookup type ORA_UER_INSIGHT_GROUP if your implementation requires more than one language.
| Task | Configuration |
| Fetch insight group |
GET /utilitiesAdmin/v1/insightGroup Example: GET https://<hostname>/api/utilitiesAdmin/v1/insightGroup A specific insight type can be fetched using: GET /utilitiesAdmin/v1/insightGroup/{id} Example: GET https://<hostname>/api/utilitiesAdmin/v1/insightGroup/C1XA |
| Edit insight group |
POST /CXIPlatformService/v1/CXIReferenceEntity/insightGroup Example: POST https://<hostname>/api/CXIPlatformService/v1/CXIReferenceEntity/insightGroup
| Create a new insight group |
Parent topic: View, Edit and Add Reference Types
