Oracle Intelligent Advisor Tasks
Customer Experience for Utilities solutions can be integrated with Oracle Intelligent Advisor (OIA) to enable your sales and service employees to use OIA interviews to gather information from customers or prospects, and provide them with recommended next steps.
You can use OIA with Customer Experience for Utilities to:
Enable pay plan features in CX for Utilities Agent Service
Enable needs analysis features in CX for Utilities Sales
Unless otherwise noted, all of the topics listed in this topic are available in the Oracle Intelligent Advisor library. For additional information, see Integrate with Oracle Intelligent Advisor in the Implementing Service Center with the Redwood User Experience Guide.
Complete these tasks related to using supported Oracle Intelligent Advisor features in your Customer Experience for Utilities implementation.
| Task | Description | Documentation |
| Oracle Intelligent Advisor configurations |
In order to use the delivered pay plan or needs analysis flows, you must complete these tasks:
Configurations for the Create Pay Plan and Energy Efficiency Program (needs analysis) sample interviews are seeded in the application. If you want to customize the interface or the rules associated with the interview, you must edit the flow and schema, and deploy it again. |
For information about setting profile options, see Setting Profile Options. Review the tasks listed in these sections of the OIA library:
For a sample payment plan flow and schema, see My Oracle Support Article 2906638.1. For a sample needs analysis flow and schema for an energy efficiency program, see My Oracle Support Article 3007543.1. When using the above articles, download the zip file and then upload the schema and then upload the flow. |
| Update the product table if using the needs analysis sample interview |
If you are using needs analysis sample interview, you must update the products table in the interview rules and complete the following tasks:
For additional information see:
Add a new needs analysis interview This task assumes the user has knowledge of the Visual Builder and Oracle Intelligent Advisor systems and processes. |
| Update seeded interview properties | To update the name and description of an interview, or to deactivate an interview, add the interview in “EXTENDED_OIA_INTERVIEWS” in the same way as if adding new interviews. For example, use IDs such as ORA_ENERGY_EFFICIENCY for your energy efficiency plan interview or ORA_PAYPLAN for your create pay plan interview. |
For additional information see: |
Parent topic: Configure Fusion Applications
