Premise Tree
The premise tree displays a hierarchical list of the components within a premise. You must also identify the URL associated with your premise tree. The following premise tree components are delivered with the solution.
ASSOC_ACCT: oj-ux-ico-file
COMPONENT: oj-ux-ico-chart-bar
DEVICE: oj-ux-ico-odometer
METER: oj-ux-ico-odometer
PREMISE: oj-ux-ico-city
SPCOMP: oj-ux-ico-chart-bar
SPDEV: oj-ux-ico-odometer
SVC_CONT: oj-ux-ico-outage
SVC_POINT: oj-ux-ico-location-pin
treeName: C1-CX-PremiseTree
UNLINK_SP: oj-ux-ico-location-pin
- HIST_PREM: oj-ux-ico-city
- HIST_PREMS: oj-ux-ico-city
- TRANSFORMER: oj-ux-ico-timeline
- FEEDER: oj-ux-ico-divert
- SUBSTATION: oj-ux-ico-industry
The table below provides additional details on the tasks you need to complete.
| Task | Configuration | Comments |
| Fetch a premise tree record |
GET /utilitiesAdmin/v1/premiseTree Example: GET https://<hostname>/api/utilitiesAdmin/v1/premiseTree
A specific premise tree record can be fetched using: GET /utilitiesAdmin/v1/premiseTree/{id} Example: GET https://<hostname>/api/utilitiesAdmin/v1/premiseTree/PREMISE |
| Specify your URL |
POST /CXIPlatformService/v1/CXIReferenceEntity/premiseTree Example: POST https://<hostname>/api/CXIPlatformService/v1/CXIReferenceEntity/premiseTree
Oracle recommends using the same value for 'id' and 'name'. |
| Edit a URL |
Oracle recommends using the same value for 'id' and 'name'. Multiple premise tree records can be edited together by adding them to the “items" list.
| Delete a URL |
| Add inactive node type for premise |
Parent topic: View, Edit and Add Reference Types
