Standard Usage Identifier
The following standard usage identifiers are delivered with the solution. Each usage identifier is associated with a unit of measure. You must activate the identifiers along with the units of measure that are associated with your utility, or add additional identifiers, if necessary. You can also change the colors associated with each entry to match your utility branding colors. All standard usage identifiers are delivered inactive.
| Code | Description | Associated Unit of Measure |
| KWH-- | Kilowatt Hour | KWH |
| KWH-ON- | Kilowatt Hour - Peak | KWH |
| KWH-OFF- | Kilowatt Hour - Off-peak | KWH |
| KWH-MID- | Kilowatt Hour - Mid | KWH |
| KW-- | Kilowatt | KW |
| TH-- | Therm | TH |
| GAL-- | Gallons | GAL |
The table below provides additional details on the tasks you need to complete.
| Task | Configuration | Comments |
| Fetch a standard usage identifier |
GET /utilitiesAdmin/v1/standardUsageIdentifier?q=active=true Example: GET https://<hostname>/api/utilitiesAdmin/v1/standardUsageIdentifier?q=active=true
A specific identifier can be fetched using: GET /utilitiesAdmin/v1/standardUsageIdentifier/{id} Example: GET https://<hostname>/api/utilitiesAdmin/v1/standardUsageIdentifier/KW-- |
| Activate a standard usage identifier |
POST /CXIPlatformService/v1/CXIReferenceEntity/standardUsageIdentifier Example: POST https://<hostname>/api/CXIPlatformService/v1/CXIReferenceEntity/standardUsageIdentifier
Complete this task for every standard usage identifier associated with your utility. Multiple standard usage identifier can be activated together by adding them to the “items” list. |
| Edit a standard usage identifier |
POST /CXIPlatformService/v1/CXIReferenceEntity/standardUsageIdentifier Example: POST https://<hostname>/api/CXIReferenceEntity/v1/CXIReferenceEntity/standardUsageIdentifier
Multiple standard usage identifier can be edited together by adding them to the “items” list. |
| Create a new standard usage identifier |
Oracle recommends using the same value for 'id' and 'usageIdentifier'. Also, 'description' is a translatable field, so the value should be the relevant lookup code created under the lookup type ORA_UER_USAGE_IDENTIFIER. Multiple standard usage identifier can be created together by adding them to the “items” list. For additional information on Lookups, see Overview of Lookups.
Parent topic: View, Edit and Add Reference Types
