Units of Measure
You must activate the units of measure that are associated with your utility, or add additional units of measure, if necessary. You can also update the display order of the units of measure. All units of measure are delivered inactive.
The following units of measure, and specified display order, are delivered with the solution.
| Service Type | Unit of Measure | Display Order |
| Electric | KW: Kilowatts | 5 |
| Electric | KWH: Kilowatt Hours | 10 |
| Electric | MWH: Megawatt Hours | 15 |
| Gas | CCF: Hundred Cubic Feet | 5 |
| Gas | TH: Thermal Units | 10 |
| Water | GAL: Gallons | 5 |
The table below provides additional details on the tasks you need to complete.
| Task | Configuration | Comments |
| Fetch a unit of measure |
GET /utilitiesAdmin/v1/unitOfMeasure?q=active=false Example: GET https://<hostname>/api/utilitiesAdmin/v1/unitOfMeasure?q=active=false
A specific unit of measure record can be fetched using: GET /utilitiesAdmin/v1/unitOfMeasure/{id} Example: GET https://<hostname>/api/utilitiesAdmin/v1/unitOfMeasure/KW |
| Activate a unit of measure |
POST /CXIPlatformService/v1/CXIReferenceEntity/unitOfMeasure Example: POST https://<hostname>/api/CXIPlatformService/v1/CXIReferenceEntity/unitOfMeasure
Complete this task for every unit of measure associated with your utility. Multiple units of measure can be activated together by adding more of them to the “items” list. |
| Edit a unit of measure |
Multiple units of measure can be edited together by adding more of them to the “items” list. |
| Edit the display order of a unit of measure |
POST /CXIPlatformService/v1/CXIReferenceEntity/unitOfMeasure Example: POST https://<fabric host>/api/CXIPlatformService/v1/CXIReferenceEntity/unitOfMeasure
| Create a new unit of measure |
Be aware that 'description' is a translatable field, so the value should be the relevant lookup code created under the lookup type ORA_UER_UOM. Multiple units of measure can be created together by adding more of them to the “items” list. For additional information on Lookups, see Overview of Lookups. |
Parent topic: View, Edit and Add Reference Types
