Fusion Data Synchronization
In the ongoing data synchronization process, updating data from the Customer Experience for Utilities solutions is an asynchronous update that is completed using Oracle Signals. This process requires you to:
Enable Signals in your profile options
Provision a user role to fetch signals from Oracle Fusion applications
Update existing signal definitions (optional)
Understand the naming conventions for signals
Create a user in your Oracle Utilities customer information system to persist data
The remaining steps in this topic are written for Oracle Utilities Customer Cloud Service. If you are using another Oracle Utilities customer information system, refer to the documentation for your identity management system to determine how to complete these steps for your implementation. Contact your implementation team for additional assistance.
Additionally, extended attributes are currently not supported. Signal definitions are seeded and cannot be modified. Seeded signal definition cannot be configured to have an extended attribute. Create, update, and delete of extended attributes is not supported.
There is a limitation regarding Signals. If you change a Phone type, a signal is not triggered, and can cause data to become inconsistent between Oracle Fusion and your CIS system. To mitigate this issue, users should use the Communication Preferences screen to change the phone type, as these changes are supported by the data synchronization process.| Task | Details |
| Set Profile Options for Signals |
To implement near real-time synchronization for contact and account records, you must set the following profile options:
For information about setting profile options, see Set Profile Option Values in the Oracle Fusion Implementing Applications Guide. |
| Provision User Role to Fetch Signals |
Add the Sales Administrator role (ORA_ZBS_SALES_ADMINISTRATOR_JOB) to the provisioned FABRIC_CX4U_SYSTEM_USER user. For additional information, see Manage Roles and Users. |
| Update Existing Signal Definitions (Optional) |
| Understand the Naming Conventions for Signals |
When cloning a signal definition, the signal should be modified to use the <Signal Name>/<Version> format. For example:
If there are multiple active versions with the same signal name, only the higher version is considered for the polling. In the above example, only Create Account ContactPoint for CX4U/v2 would be considered for signal polling, and Create Account ContactPoint for CX4U/v1 would be ignored. |
| Create an Oracle Utilities User to Persist Data |
To create the utilities user that enables data synchronization, complete these steps:
Parent topic: Ongoing Data Synchronization
