Viewing Activities for a Premise
When you access the Premise screen, you can view specific field activities that the utility has had that are associated with the premise. The Activity panel displays the most recent field activities, and includes a View all activities link at the bottom.
Field activities are specific types of tasks performed by utility field personnel. For example, manual installation of a physical meter, severance processes, and stopping, starting, or transferring service. Once created, field activities are sent to a field work system, where they are scheduled and assigned to a field work crew. When the task is completed by the crew, the field work system sends a response, and the field activity is updated.
Activities that are associated with a customer, such as phone calls or chats, are not displayed here.
When you click the View All Activities link, the Activities drawer opens on the right of the screen, and includes a longer list of activities. You can use the Filter By button to refine your activity list to specific categories.
By default, the list displays activity records in six-month increments for the past three years. You can use the Date Range button to enter a more specific time frame. For example, if your system is set up to display two years of historical data, you cannot search for activities that happened more than two years ago.
View Activities from the Premise Screen
To view activities from the Premise screen:
- Access the Premise screen.
- View the most recent activities in the Activities section, or click the View All Activities link to open the Activities drawer on the right of the screen.
- To filter records by activity type, click the Filter By button, click on the activity types that you want to view, and then click Apply.
- To filter records by date range, click the Date Range button, use the calendars to select a date range of six months or less within the last three years, and then click Apply.
- The system displays all activity records that match your filter criteria. You can scroll down the list to view each activity.
- Click on an activity to view additional details or to access the record.
- To clear filters or date range search criteria, click either the Filter By or Date Range buttons, and then click Reset. The search results then include all records for the time frame configured by your utility.
Parent topic: Managing Premises
