Managing Contact Methods
Each utility contact must have at least one contact method associated with their billing account. Contact methods can include:
- Phone numbers
- Email addresses
- Social networks
- Websites
- SMS (Short Message Service)
- Telex
- EDI (Electronic Data Interchange)
- Electronic file transfer
Utilities can determine which of these communication types is available in CX for Utilities Sales during the implementation and configuration process. Additionally, each contact method has types. For example, you can specify that a phone number is one of these types:
- Mobile phone
- Work phone
- Fax number
- Land phone
Your utility can create additional phone types as needed.When a communication method is added, the first record for a particular method is always marked as the primary contact method. For example, if the billing account has only one email address on file, that email address is marked as the primary email contact. If there are multiple records for a contact method, you can specify which of those records is the primary record. You cannot delete a primary contact method.
Adding a Contact Method
To add a contact method:
- From Account 360, complete one of these steps:
- Use the Show Contacts smart action to view a list of contacts. On the contact you want to view, use the Edit linked billing accounts option to open the <Contact Name> Billing Account Summary drawer, which lists all billing accounts associated with the contact. Select the Update Communication Preferences option from the action menu on the billing account you want to update.
- Search for and select a billing account. Select View contacts from the action menu, which opens a drawer with a list of contacts. Select the Update Communication Preferences option from the action menu on the contact you want to update.
- The system opens the Set Communication Preferences drawer.
- In the Contact Methods section, click the + Add Contact Method button.
- Select a value from the Contact Method field.
- Enter the contact method details in the field(s) below the Contact Method field. The fields that appear here differ, depending on the contact method that you select. For example, if you select Phone, you can then enter the phone type, country code, area code, phone number, and extension.
- To mark the record as the primary contact method, click the Primary option. If the record you are adding is the only contact method of this type (for example, the only phone number record), the system automatically marks it as the primary contact method.
- Click Add to save your changes.
Parent topic: Managing Contact Methods
Editing Contact Methods
After you create contact methods, you can edit or delete them.
To edit or delete a contact method:
- To edit an existing contact method record, in the Contact Methods section of the screen, click the Edit icon next to the record you want to edit. The system displays the contact method details. Edit them as necessary, and then click Update.
- To delete a contact method record, click the Delete icon next to the record you want to delete, and then click Continue on the Delete contact method window. Be aware that you cannot delete a contact method record that is marked as a primary contact method.
