Home Energy Analysis FAQs
These FAQs are related to the Home Energy Analysis survey tool, which prompts customers to answer simple questions about their home and energy habits.
What is the purpose of the Home Energy Analysis?
Our research has shown that customers who want to become more energy efficient are often held back by misconceptions about how their energy use is distributed throughout their homes. With this in mind, the Home Energy Analysis survey walks you through questions about your home and then visually displays an estimated breakdown of your energy use in different categories, such as heating, cooling, or appliances. It also displays personalized tips to help you take action. This information is meant to help you focus and save.
How do you calculate my energy use for each category?
The way we calculate the energy use for each category depends on several factors, such as how much data you have and how the feature has been configured for you.
In general, the survey calculator starts with the average percentage of energy use for a specific category, such as heating or cooling. These averages are based on how energy is used in homes throughout your utility's service territory, and is pre-populated before you start answering any questions. We derive this percentage by getting census and climate zone data from the U.S. Energy Information Administration's Residential Energy Consumption Survey. We then use your responses to the Home Energy Analysis to adjust that baseline and make it more personalized to you.
If we have more data about your home (such as weather data, historical bills, and data from a smart meter), then the survey calculator can generate estimates for annual as well as bill-level breakdowns of your energy use. This way you may get more accurate and specific estimates for each bill period, such as an estimate of how much money you spent in each category.
How many appliances can be included in the breakdown?
The list of available appliance categories varies slightly depending on the characteristics of your home.
| Scenario | Available Categories |
What time period does the survey cover?
By default, the survey estimates and displays your average annual energy use in different categories. This lets you see how your energy use is distributed in your home regardless of the season of year, so you can plan and take action accordingly.
Depending on how much data you have and how the feature has been configured for your utility, you may also be able to view a breakdown of your energy use by bill period. In this case, you can usually see an estimate of how much money you spent in each category.
How can these values be more accurate?
The best way to make your breakdown more accurate is to take the Home Energy Analysis survey. Or I can look at it for you, and we can confirm that the information we have about your home is correct. I can also check your Home Profile.
Instructions for CSRs:
| Action | Steps |
| Check the customer's Home Energy Analysis survey. |
| Check customer's Home Profile. |
