Sending a Follow-Up Email
The Follow-up Communications module is a tool in the Bill Advisor that allows CSRs to send an email to a customer after the end of a call. The email thanks the customer for calling and provides brief details about a utility promotion, rebate, or energy-saving tip.
To send a follow-up email:
  1. Sign in to the Customer Service Interface.
  2. Go to the Bill Advisor tab, and search for and open a customer's account.
  3. Navigate to the Follow Up Communications section.
  4. In the Customer email field, add the customer's email address, and click Save.
  5. Select a template to use for the follow-up email. You can click the Preview button to see what it will look like for the customer.
    The preview does not include the email subject line. The default subject line is, "Following up on your recent call to <utility name>". However, this language may have been customized for your utility, and there may be a different subject line for each email template. Contact your supervisor if you have any questions.
  6. After you have selected the desired template, click Send.
