Create an Instance
As an Oracle Energy and Water Data Intelligence cloud account administrator and service administrator, typically, you create an Oracle Energy and Water Data Intelligence instance with public IP addresses. Optionally, you can create a Oracle Energy and Water Data Intelligence instance with private IP addresses. You may also plan for additional test environments.
For details and instructions, see Create an Oracle Energy and Water Data Intelligence Instance. An overview of this task is provided below.
Public Environment
By default, Oracle Energy and Water Data Intelligence is a public service deployed in the Oracle Services Network with public IP addresses.
Private Environment
This instance is deployed in a virtual cloud network with private IP addresses in your Oracle Energy and Water cloud account.
For both types of instances, you need the following information:- The environment type, for example, development or test.
- The environment name and URL.
- The JWT (JSON web token) certificate that was uploaded and the associated private key. The recommended authentication type is JWT token-based with security certificate and private key renewal; see Using JWT Token with Fusion Analytics.
- The identity stripe or domain name used for the environment.
- The compartment name.
- The region name.
- An Oracle Autonomous Data Warehouse password.
- An email address for provisioning and any future updates.
- The compartment hosting the virtual cloud network.
- The compartment hosting the private subnet.
- The compartment hosting the network security group.
- The virtual cloud network name.
- The private subnet name.
- The network security group name.
Create the production instance along with the development and additional test instances simultaneously.
