Typical Workflow to Set Up Oracle Utilities Data Intelligence
If you’re setting up Oracle Utilities Data Intelligence for the first time, then follow these tasks as a guide.
| Task | Description |
| Set up user access to Oracle Utilities Data Intelligence using single sign-on. | You can set up how users from Oracle
Utilities cloud applications access Oracle Utilities Data Intelligence using single
sign-on. This setup simplifies how you manage user names and passwords.
It enables you to synchronize users and roles in Oracle
Utilities cloud applications with Oracle Identity Cloud Service and then enable
these users to access Oracle Utilities Data Intelligence.
See Set Up User Access to Oracle Utilities Data Intelligence Using Single Sign-On. |
| Create an Oracle Utilities Data Intelligence instance. | Create a service instance to manage your cloud resources. |
| Verify your instance and sign in. | Verify your service instance when you receive an email from Oracle that your Oracle Utilities Data Intelligence service instance is ready. |
