Load Performance Tuning
The data specifics – volumes, structure and other aspects – may justify customizing the default configurations for all or some tables.
The SQL Loader is processing data according to the Control File. The fragment that contains general load parameters is stored as Managed Content that is referenced on the Conversion Task Type.
You can create new Managed Content, configure the Conversion Task Type and specify the new settings on Conversion Master Configuration, for all or specific Tables or Maintenance Objects.
