Defining Document Types
The Document Type portal is used to view and maintain document types.
Refer to Understanding Documents for more information.
You can access this portal from Admin, select D, then select Document Type.
The following zones may appear as part of the portal’s Main tab page:
- Document Type List: This zone lists all the document types. Broadcast a record to display the details of a selected record.
- Document Type: This zone provides information about the selected document type.
