Maintaining Maintenance Events
The Maintenance Event portal is used to display and maintain a maintenance event record.
Refer to About Preventive Maintenance for more information.
You can access the portal from Menu, select Preventive Maintenance, then select Maintenance Event. You are brought to a query portal with options for searching for a specific record. Once a maintenance event has been selected, you are brought to the maintenance portal to view and maintain the selected record.
- Maintenance Event: This zone displays information about the maintenance event record, including maintenance plans and work activity schedule defaults.
- Maintenance Event Information: This zone displays summary information about the work activities associated with the maintenance event.
The following zones may appear as part of the portal's Work Detail tab page:
- Plan Trigger: This zone displays plan trigger information about the maintenance event.
- Activity: This zone displays the work activities associated with the maintenance event.
The following zones may appear as part of the portal's Inventory tab page:
- Stock Item Availability: This zone displays stock item availability information for the maintenance event.
