Importing Data to Geodatabase
After the Geodatabase is set up, make sure that the necessary customer specific datasets are imported
To import the work locations dataset:
- Download the Oracle Utilities Work and Asset Management V2.4.0.0.0 ESRI Integration component from the Oracle Utilities Work and Asset Management V2.4.0.0.0 package.
- Copy the file to the server where ArcGIS is installed and unzip it.
- Navigate to the XML workspace file located at /metadata/ xmlWorkspaceDocument/WORKLOCATIONS.XML.
- Copy the workspace file to the relevant destination folder.
- Select Database Connections in the Catalog.
- To import the XML workspace document:
- Select Schema Only in the import options.
- Specify the path of the work locations XML file.
- Once the import process is complete, the Contents tab displays the WorkLocationDataset imported into the Geodatabase.
Note: Note that the Map Notes dataset configuration is optional. However,
to display a Map Notes layer, any layer dedicated to capture notes/redlining
can be used. Map Notes is a customer specific layer and Oracle Utilities
Work and Asset Management does not own/manage it and is not delivered
as part of base product. To create a feature class in Geodatabase,
refer to ESRI ArcGIS instructions.
Register data with the ArcGIS Server using Manager. For instructions refer to ESRI ArcGIS.
