Maintaining Maintenance Specifications
The Maintenance Specification portal is used to display and maintain a maintenance specification record.
You can access the portal from Menu, select Preventive Maintenance, then select Maintenance Specification. You are brought to a query portal with options for searching for a specific record. Once a maintenance specification has been selected, you are brought to the maintenance portal to view and maintain the selected record.
  • Specification: This zone displays information about the maintenance specification and identifies the maintenance schedule.
  • Specification Assets: This zone lists all the assets associated with the specification record.
  • Attachments: This zone lists attachments associated with the specification.
