Defining Unit of Measure Resources
The Unit of Measure —Resource portal is used to maintain unit of measure resources. A unit of measure is used to quantify a resource.
You can access this portal from Admin, select U, then select Unit of Measure-Resource.
The following zones may appear as part of the portals Main tab page:
  • Resource UOM List: This zone lists all the units of measure. Broadcast a record to display the details for the selected record.
  • Resource UOM: This zone provides information about the selected resource UOM.
