Maintaining Network Locations
The Network Location portal is used to display and maintain network locations.
Refer to About Network Locations for more information.
You can access the portal from Menu, select Digital Asset Management, then select Network Location. You are brought to a query portal with options for searching for a specific record. Once a network location has been selected, you are brought to the maintenance portal to view and maintain the selected record.
Network Location: This zone displays general information about the network location, such as Facility ID, Start and End Date/Time, Feeder, and Substation.
SP Related to Network Location: This zone lists the service points associated with the network location record.
