Template Construction Work Orders
Template construction work orders are construction work orders that can be re-used to help your organization avoid repeat planning of the same construction work for similar jobs.
A short Description and the Work Priority is required to create the template and, once created, template construction work activities can then be added to the template construction work order. Template construction work activities can also be added to non-final construction work orders using the Add Activity or Add Activity(s) From Template Construction Work Order hyperlinks from the Construction Work Order Activity Info zone on the construction work order.
Also, construction work orders can be created directly from the template construction work order record by selecting the Create Construction Work Order button from the Title bar. User can then select either an Asset Location or Work Location and the Storerooms in order for the construction work order to be created and for the template construction work activities to populate.
