Defining Failure Repairs
The Failure Repair portal is used to display and maintain failure repairs.
You can access the portal from Admin, select F, then select Failure Repair.
- Failure Repair List: This zone lists all failure repair records. Broadcast a record to display the details of the selected record.
- Failure Repair: This zone identifies the repair that will be made to the failed asset.
- Included on Failure Profile: This zone lists the failure profiles associated with a particular failure repair.
