Defining Maintenance Managers
The Maintenance Manager portal is used to display and maintain maintenance managers.
Refer to Understanding Preventive Maintenance for more information.
You can access the portal from Admin, select M, then select Maintenance Manager.
- Maintenance Manager List: This zone lists all maintenance manager records. Broadcast a record to display the details of the selected record.
 - Maintenance Manager: This zone provides information about the selected maintenance manager.
