Maintaining BOM Parts
The BOM Part portal is used to display and maintain a bill of material parts record.
You can access the portal from Menu, select Asset Management, then select BOM Part. You are brought to a query portal with options for searching for a record. Once a record has been selected, you are brought to the Bill of Materials tab on the Stock Item record to view and maintain the selected record.
The following zones may appear as part of the portal's Bill of Materials tab page:
  • Bill of Materials: This zone displays information about the component parts for the particular stock item.
  • Referencing BOM’s: This zone lists the BOMs that reference this particular BOM part.
  • Attachments: This zone enables users to manage all types of attachments for the BOM part.
  • Notes: This zone displays any notes associated with the BOM part record.
