Maintaining Preventive Maintenance Triggers
The Maintenance Trigger portal is used to display and maintain a maintenance trigger record.
Refer to About Preventive Maintenance for more information.
You can access the portal from Menu, select Preventive Maintenance, then select Maintenance Trigger. You are brought to a query portal with options for searching for a specific record. Once a maintenance trigger has been selected, you are brought to the maintenance portal to view and maintain the selected record.
- Maintenance Trigger: This zone displays information about the maintenance trigger record, such as processing information, asset qualification conditions, and failure statistics.
 - Activity: This zone lists the work activities associated with the maintenance trigger record.
 - Failure Information Quick Add: This zone enables the addition of failure information to the maintenance trigger record.
 - Planned Failure Information: This zone displays planned failure information associated with the maintenance trigger record.
