Maintaining Vendors
The Vendor portal is used to display and maintain a vendor record.
You can access the portal from Menu, select Purchasing, then select Vendor. You are brought to a query portal with options for searching for a specific vendor. Once a vendor has been selected, you are brought to the maintenance portal to view and maintain the selected record.
  • Vendor: This zone displays information about the vendor.
  • Vendor Location: This zone lists the locations associated with the vendor record.
The following zones may appear as part of the portal's Blanket Contracts tab page:
  • Vendor Active Blanket Contracts: This zone lists the blanket contract for this vendor record.
The following zones may appear as part of the portal's Open Purchase Requisitions tab page:
  • Vendor Open Purchase Requisition: This zone displays the open purchase requisitions associated with this vendor record.
The following zones may appear as part of the portal's Purchase History tab page:
  • Vendor Purchase Order History Summary: This zone displays a summary of purchase orders associated with this vendor record.
