Maintaining Work Location
The Work Location portal is used to display and maintain a work location record.
Refer to About Work Activities for more information.
You can access the portal from Menu, select Work Management, then select Work Location. You are brought to a query portal with options for searching for a specific work location. Once a work location has been selected, you are brought to the maintenance portal to view and maintain the selected record.
- Work Location: This zone displays information about the work location, such as address and latitude and longitude coordinates.
 - Attachments: This zone enables users to manage all types of attachments for the work location record.
