Other Related Functionality
Oracle Utilities Digital Asset Cloud Service and Oracle Utilities Digital Asset Management both share significant functionality with Oracle Utilities Work and Asset Management. The following functional areas are also available with Oracle Utilities Digital Asset Cloud Service and Oracle Utilities Digital Asset Management.
Note: Menu items for some features in the above functional areas
may may have moved in Oracle Utilities Digital Asset Cloud Service
and Oracle Utilities Digital Asset Management. To access to a specific
menu item, enter the name of the menu item in the Unified Search field. For instance, to access the
"Work Order, Search" menu item, you could enter
"work order" (the search is case-insensitive) in the Unified Search field, and select "Work Order" from
the list that appears below the text field.
