Defining Compatible Unit Sets
The Compatible Unit Set portal is used to display and maintain compatible unit sets.
Refer to Understanding Construction Work for more information.
You can access the portal from Admin, select Construction Work Management, then select Compatible Unit Set. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
- Compatible Unit Set: This zone provides information about the compatible unit set.
- Compatible Units: This zone displays a table of the compatible units in the set and enables you to link an existing compatible unit or add a new compatible unit.
- Compatible Units Hierarchy: This zone displays a tree view of the compatible units in the set.
- Attachments: This zone enables users to manage all types of attachments for the compatible unit set record.
- Notes: This zone displays notes about the compatible unit set.
