Filter | Usage |
Browser Cache Filter | Browser Client side caching settings - Used with maxAge - Max Age for pages. |
CSS Stylesheet Direction Filter | CSS Filter |
Doctype Replace Filter | JDOC Filter |
FlushAll Redirect Filter | Cache management utility Filter |
GZip Compression Filter | HTTP 1.1 compression filter |
Header Security Filter | OWASP processing of HTTP headers using SAMEORIGIN |
HTML Comment stripping Filter | Removal of comments from HTTP transmission |
Image Browser Cache Filter | Browser Client side caching settings for image files - Used with maxAgeI - Max Age for Images. |
Image RTL Filter | Right to Left support Filter |
Javascript Comment stripping Filter | Removal of comments from javascript transmission |
Minification Filter | Optimization code |
Privacy Page Redirect Filter | Privacy page redirect to /cm/privacy.html |
Request Context Filter | Generic context Filter |
Rest Security Filter | REST security support |
Security Filter | Generic security filter to delegate security to JEE container |
Timezone Database ContentType Filter | Time zone support |
Parameter | disableCompression |
Description | Enables or disables compression between the Web Application Server and Business Application Server (true or false). |
Ordinality | Mandatory |
Valid Values | [true|false] |
Source | Derived from WEB_ISDEVELOPMENT - Development Environment parameter from ENVIRON.INI. It is highly recommended to set to false for all environment exception is development environments using Oracle Utilities SDK. |
Applicability | Web Application Server |
Example: | <context-param> <param-name>disableCompression</param-name> <param-value>false</param-value> </context-param> |
Parameter | maxAge |
Description | Set the duration (in seconds) to store images, in the Client Cache, from the product on the client browser. |
Valid Values | In accordance with JEE Standards Default: 28850 |
Source | Derived from WEB_MAXAGEI - Image Cache parameter from ENVIRON.INI. It is highly recommended to set to the default unless otherwise recommended. |
Example: | <filter> <filter-name>Image Browser Cache Filter</filter-name> <filter-class>com.splwg.base.web.services.BrowserCacheFilter</filter-class> <init-param> <param-name>maxAge</param-name> <param-value>28850</param-value> </init-param> </filter> |
Description | Set the duration (in seconds) to store page structures from the product, in the Client Cache, on the client browser. |
Valid Values | |
Source | Derived from WEB_MAXAGE - Text Cache parameter from ENVIRON.INI. It is highly recommended to set to the default unless otherwise recommended. |
Example: | <filter> <filter-name>Browser Cache Filter</filter-name> <filter-class>com.splwg.base.web.services.BrowserCacheFilter</filter-class> <init-param> <param-name>maxAge</param-name> <param-value>28850</param-value> </init-param> </filter> |
Parameter | auth-method |
Description | Sets the JEE authentication method for the product. |
Valid Values | [BASIC|CLIENT-CERT|FORM] |
Source | Derived from WEB_WLAUTHMETHOD - Authentication Method parameter from ENVIRON.INI. Depending on the value this may lead to further settings being implemented. • BASIC - Enables the operating system to provide the logon dialog. • CLIENT-CERT - Enables an external solution such as a SSO solution, Kerberos or any security implementing client certificates to provide credentials. • FORM - This instructs the product to implement the following additional settings: • WEB_FORM_LOGIN_PAGE - Default Form Login Page and WEB_FORM_LOGIN_ERROR_PAGE - Default Form Login Error Page need to be set to indicate the form to use for online authentication. • WEB_HELP_FORM_LOGIN_PAGE - Help Form Login Page and WEB_HELP_FORM_LOGIN_ERROR_PAGE - Help Form Login Error Page need to be set to indicate the form to use for online help authentication. |
Example: | <login-config> <auth-method>FORM</auth-method> <form-login-config> <form-login-page>/loginPage.jsp</form-login-page> <form-error-page>/formLoginError.jsp</form-error-page> </form-login-config> </login-config> |
Parameter | fieldValuesAge |
Description | Set the duration (in seconds) to hold data in the Server Cache. |
Valid Values | 1 - 2147483647 Default: 3600 |
Source | Defaulted from template. Changes to the value require a Implementing Custom Templates. |
Applicability | Web Application Server, Business Application Server. |
Example: | <env-entry> <description>How long to cache drop down values in seconds</description> <env-entry-name>fieldValuesAge</env-entry-name> <env-entry-type>java.lang.Integer</env-entry-type> <env-entry-value>3600</env-entry-value> </env-entry> |
Parameter | disableUIPageCompression |
Description | Enables or disables compression between the browser and Web Application Server (true or false). |
Example: | <env-entry> <description>Disable UIPage compression</description> <env-entry-name>disableUIPageCompression</env-entry-name> <env-entry-type>java.lang.Boolean</env-entry-type> <env-entry-value>false</env-entry-value> </env-entry> |
