| Table Name | Index Name |
| CI_TD_ENTRY | CM_ILM_XT039S8 |
| D1_ACTIVITY | CM_ILM_D1T319S1 |
| D1_COMM_IN | CM_ILM_D1T386S1 |
| D1_COMM_OUT | CM_ILM_D1T380S1 |
| D1_COMPL_EVT | CM_ILM_D1T340S1 |
| D1_DVC_EVT  | CM_ILM_D1T400S4 |
| D1_INIT_MSRMT_DATA | CM_ILM_D1T304S4 |
| D1_USAGE | CM_ILM_D1T281S2 |
| D1_USAGE_EXCP | CM_ILM_D1T443S1 |
| D1_VEE_EXCP | CM_ILM_D1T308S2 |
| D1_SP_SNAP_DL | CM_ILM_D1T434S1 |
| D1_SP_UNR_USG_SNAP_DL | CM_ILM_D1T438S1 |
| D1_SP_USG_SNAP_DL | CM_ILM_D1T436S1 |
| D1_SP_VEE_EXCP_SNAP_DL | CM_ILM_D1T440S1 |
| F1_BUS_FLG | CM_ILM_F1T681S2 |
| F1_ERASURE_SCHED | CM_ILM_F1T756S1 |
| F1_OBJ_REV | CM_ILM_FT035S6 |
| F1_OUTMSG | CM_ILM_FT010S2 |
| F1_PROC_STORE | CM_ILM_F1T747S1 |
| F1_REMOTE_MSG | CM_ILM_F1T735S7 |
| F1_STATS_SNPSHT | CM_ILM_F1C706S2 |
| F1_SVC_TASK | CM_ILM_F1C474S3 |
| F1_SYNC_REQ | CM_ILM_F1T014S4 |
| F1_SYNC_REQ_IN | CM_ILM_F1T191S3 |
| Table  Name | Table Partitioning  Type (Partitioning, Sub-Partitioning Key) | Index Name | Index  Columns | Index Type  Global or Local | Index  Partitioning Sub-Partitioning Key | ILM_DT Initial Load |
| CI_TD_ENTRY (Parent) | RANGE (ILM_DT,  TD_ENTRY_ ID) | CI_TD_ENTRY. CRE_DTTM | ||||
| XT039P0 | TD_ENTRY_ID | Global  Partitioned | RANGE  (TD_ENTRY_ID) | |||
| XT039S2 | ASSIGNED_TO,  TD_ENTRY_ID | Global  | ||||
| XT039S3 | ENTRY_STATUS_FLG,  ASSIGNED_TO | Global | ||||
| XT039S4 | ROLE_ID, TD_TYPE_CD, ENTRY_STATUS_FLG, TD_PRIORITY_FLG, ASSIGNED_TO, CRE_DTTM | Global | ||||
| XT039S5 | BATCH_CD, BATCH_NBR, ENTRY_STATUS_FLG | Global | ||||
| XT039S6 | TD_ENTRY_ID, ASSIGNED_TO, ENTRY_STATUS_FLG | Global  | ||||
| XT039S7 | COMPLETE_USER_ID, COMPLETE_DTTM, TD_ENTRY_ID | Global | ||||
| CM_ILM_XT039S8 | ILM_DT, ILM_ARCH_SW, TD_ENTRY_ID | Local Partitioned | ||||
| CI_TD_ENTRY_CHA | Reference Partitioning | XT701P0 | TD_ENTRY_ID, CHAR_TYPE_CD, SEQ_NUM | Global  Partitioned | ||
| XT701S1 | SRCH_CHAR_VAL, CHAR_TYPE_CD, TD_ENTRY_ID | Global | ||||
| XT701S2 | CHAR_VAL_FK1 | Global | ||||
| CI_TD_DRLKEY | Reference Partitioning | XT037P0 | TD_ENTRY_ID, SEQ_NUM | Global Partitioned | ||
| XT037S1 | KEY_VALUE, TD_ENTRY_ID | Global | ||||
| CI_TD_LOG | Reference Partitioning | XT721P0 | TD_ENTRY_ID, SEQ_NUM | Global Partitioned | ||
| XT721S1 | LOG_DTTM,USER_ID, LOG_TYPE_FLG, TD_ENTRY_ID | Global | ||||
| CI_TD_MSG_ PARM (Child table of CI_TD_LOG) | Reference Partitioning | XT040P0 | TD_ENTRY_ID, SEQ_NUM | Global Partitioned | ||
| CI_TD_SRTKEY | Reference Partitioning | XT041P0 | TD_ENTRY_ID, SEQ_NUM | Global Partitioned | ||
| XT041S1 | KEY_VALUE, TD_ENTRY_ID | Global |
| F1_SYNC_REQ (Parent) | RANGE (ILM_DT, F1_SYNC_REQ_ ID) | RANGE (F1_SYNC_REQ_ID) | F1_SYNC_REQ.CRE_DTTM | |||
| F1T014P0 | F1_SYNC_REQ_ID | Global Partitioned | ||||
| F1T014S1 | BO_STATUS_CD, BUS_OBJ_CD, F1_SYNC_REQ_ID | Global | ||||
| F1T014S2 | BO_STATUS_ REASON_CD | Global | ||||
| F1T014S3 | MAINT_OBJ_CD, PK_VALUE1,  PK_VALUE2,  F1_SYNC_REQ_ID | Global | ||||
| CM_ILM_F1T014S4 | ILM_DT, ILM_ARC_SW, F1_SYNC_REQ_ID | Local Partitioned | ||||
| F1_SYNC_REQ_CHAR | Reference Partitioning | F1T017P0 | F1_SYNC_REQ_ID,  CHAR_TYPE_CD, SEQ_NUM | Global Partitioned | ||
| F1T017S1 | SRCH_CHAR_VAL | Global | ||||
| F1_SYNC_REQ_EXTRACT | Reference Partitioning | F1T019P0 | F1_SYNC_REQ_ID, SEQ_NUM | Global Partitioned | ||
| F1_SYNC_REQ_LOG | Reference Partitioning | F1T015P0 | F1_SYNC_REQ_ID, SEQNO | Global Partitioned | ||
| F1T015S1 | CHAR_TYPE_CD, CHAR_VAL_FK1 | Global | ||||
| F1T015S2 | CHAR_TYPE_CD, CHAR_VAL | Global | ||||
| F1T015S3 | BO_STATUS_REASON_CD | Global | ||||
| F1_SYNC_REQ_LOG_PARM (Child Table of F1_SYNC_REQ_LOG_PARM) | Reference Partitioning | F1T016P0 | F1_SYNC_REQ_ID, SEQNO, PARM_SEQ | Global Partitioned |
| F1_SYNC_REQ_IN (Parent) | RANGE(ILM_DT, F1_SYNC_REQ_IN_ID) | RANGE (F1_SYNC_REQ_IN_ID) | F1_SYNC_REQ_IN.CRE_DTTM | |||
| F1T191P0 | F1_SYNC_REQ_ IN_ID | Global Partitioned | ||||
| F1T191S1 | BO_STATUS_CD, BUS_OBJ_CD, F1_SYNC_REQ_ IN_ID | Global | ||||
| F1T191S2 | MAINT_OBJ_CD, EXT_PK_VALUE1, NT_XID_CD, PK_VALUE1 | Global | ||||
| CM_ILM_F1T191S3 | ILM_DT, ILM_ARCH_SW, F1_SYNC_REQ_IN_ID | Local Partitioned | ||||
| F1_SYNC_REQ_ IN_CHAR | Reference Partitioning | F1T193P0 | F1_SYNC_REQ_IN_ID, CHAR_TYPE_CD, SEQ_NUM | Global Partitioned | ||
| F1T193S1 | SRCH_CHAR_VAL | Global | ||||
| F1_SYNC_REQ_ IN_EXCP | Reference Partitioning | F1T197P0 | F1_SYNC_REQ_IN_ID, SEQNO | Global Partitioned | ||
| F1_SYNC_REQ_ IN_EXCP_PARM (Child Table of F1_SYNC_REQ_IN_EXCP) | Reference Partitioning | F1T198P0 | F1_SYNC_REQ_IN_ID, SEQNO, PARM_SEQ | Global Partitioned | ||
| F1_SYNC_REQ_ IN_LOG | Reference Partitioning | F1T194P0 | F1_SYNC_REQ_IN_ID, SEQNO | Global Partitioned | ||
| F1T194S1 | CHAR_TYPE_CD, CHAR_VAL_FK1 | Global | ||||
| F1T194S2 | CHAR_TYPE_CD,  CHAR_VAL | Global | ||||
| F1_SYNC_REQ_IN_LOG_PARM (Child Table of F1_SYNC_REQ_IN_LOG) | Reference Partitioning | F1T195P0 | F1_SYNC_REQ_IN_ID,  SEQNO, PARM_SEQ | Global Partitioned | ||
| F1_SYNC_REQ_IN_REL_OBJ | Reference Partitioning | F1T192P0 | F1_SYNC_REQ_IN_ID, MAINT_OBJ_CD, REL_OBJ_TYPE_FLG | Global Partitioned |
| F1_OUTMSG (Parent) | RANGE (ILM_DT, OUTMSG_ID) | RANGE (OUMSG_ID) | F1_OUTMSG. CRE_DTTM | |||
| FT010P0 | OUTMSG_ID | Global Partitioned | ||||
| FT010S1 | OUTMSG_STATUS_FLG, OUTMSG_TYPE_CD | Global | ||||
| CM_ILM_FT010S2 | ILM_DT, ILM_ARC_SW, OUTMSG_ID | Local Partitioned | ||||
| F1_OUTMSG_ ERRPARM | Reference Partitioning | FT011P0 | OUTMSG_ID, PARM_SEQ | Global  Partitioned |
| F1_SVC_TASK (Parent) | RANGE (ILM_DT, F1_SVC_TASK_ID) | RANGE (F1_SVC_TASK_ ID_) | F1_SVC_TASK. CRE_DTTM | |||
| F1C474P0 | F1_SVC_TASK_ID | Global Partitioned | ||||
| F1C474S1 | F1_STASK_TYPE_CD | Global | ||||
| F1C474S2 | BUS_OBJ_CD | Global | ||||
| CM_ILM_F1C474S2 | ILM_DT, ILM_ARC_SW, F1_SVC_TASK_ID | Local Partitioned | ||||
| F1_SVC_TASK_ CHAR | Reference Partitioning | F1C476P0 | F1_SVC_TASK_ID, CHAR_TYPE_CD, SEQ_NUM | Global Partitioned | ||
| F1C476S1 | SRCH_CHAR_VAL | Global | ||||
| F1_SVC_TASK_ LOG | Reference Partitioning | F1C477P0 | F1_SVC_TASK_ID, SEQNO | Global Partitioned | ||
| F1C477S1 | CHAR_TYPE_CD, CHAR_VAL_FK1 | Global | ||||
| F1C477S2 | CHAR_TYPE_CD, CHAR_VAL | Global | ||||
| F1_SVC_TASK_ LOG_PARM (Child Table of F1_SVC_TASK_ LOG) | Reference Partitioning | F1C478P0 | F1_SVC_TASK_ID, SEQNO,  PARM_SEQ | Global Partitioned | ||
| F1_SVC_TASK_ REL_OBJ | Reference Partitioning | F1C479P0 | F1_SVC_TASK_ID,  MAINT_OBJ_CD,  SEQ_NUM | Global Partitioned | ||
| F1C479S1 | MAINT_OBJ_CD, PK_VALUE1, PK_VALUE2, PK_VALUE3, PK_VALUE4, PK_VALUE5 | Global |
| F1_OBJ_REV (Parent) | RANGE (ILM_DT, REV_ID) | RANGE (REV_ID) | F1_OBJ_REV. STATUS_UPD_DTTM | |||
| FT035P0 | REV_ID | Global Partitioned | ||||
| FT035S1 | BO_STATUS_CD,  BUS_OBJ_CD,  REV_ID | Global | ||||
| FT035S2 | MAINT_OBJ_CD,  PK_VALUE1 | Global | ||||
| FT035S3 | EXT_REFERENCE_ID,  MAINT_OBJ_CD | Global | ||||
| FT035S4 | USER_ID,  MAINT_OBJ_CD | Global | ||||
| FT035S5 | PK_VALUE1 | Global | ||||
| CM_ILM_ FT035S6 | ILM_DT,  ILM_ARC_SW,  REV_ID | Local Partitioned | ||||
| F1_OBJ_REV_ CHAR | Reference Partitioning | FT037P0 | REV_ID,  CHAR_TYPE_CD,  SEQ_NUM | Global Partitioned | ||
| FT037S1 | SRCH_CHAR_VAL | Global | ||||
| F1_OBJ_REV_ LOG | Reference Partitioning | FT039P0 | REV_ID, SEQNO | Global Partitioned | ||
| F1_OBJ_REV_ LOG_PARM (Child Table of F1_OBJ_REV_ LOG) | Reference Partitioning | FT040P0 | REV_ID, SEQNO, PARM_SEQ | Global Partitioned |
| F1_BUS_FLG (Parent) | RANGE (ILM_DT,BUS_FLG_ID) | RANGE(BUS_FLG_ID) | F1_BUS_FLG. CRE_DTTM | |||
| F1T681P0 | BUS_FLG_ID | Global Partitioned | ||||
| F1T681S1 | BUS_OBJ_CD, BO_STATUS_CD, BUS_FLG_ID | Global | ||||
| CM_ILM_ F1T681S2 | ILM_DT, ILM_ARCH_SW, BUS_FLG_ID | Local Partitioned | ||||
| F1_BUS_FLG_ CHAR | Reference Partitioning | F1T684P0 | BUS_FLG_ID, CHAR_TYPE_CD, SEQ_NUM | Global Partitioned | ||
| F1T684S0 | SRCH_CHAR_VAL | Global | ||||
| F1_BUS_FLG_ LOG | Reference Partitioning | F1T685P0 | BUS_FLG_ID, SEQNO | Global Partitioned | ||
| F1T685S1 | CHAR_TYPE_CD, CHAR_VAL_FK1 | Global | ||||
| F1T685S2 | CHAR_TYPE_CD, CHAR_VAL | Global | ||||
| F1_BUS_FLG_ LOG_PARM | Reference Partitioning | F1T686P0 | BUS_FLG_ID, SEQNO, PARM_SEQ | Global Partitioned | ||
| F1_BUS_FLG_ REL | Reference Partitioning | F1T682P0 | BUS_FLG_ID, BUS_FLG_REL_ TYPE_FLG, SEQ_NUM | Global Partitioned | ||
| F1_BUS_FLG_ REL_OBJ | Reference Partitioning | F1T683P0 | BUS_FLG_ID, BUS_FLG_REL_ OBJ_TYPE_FLG, SEQ_NUM | Global Partitioned |
| F1_REMOTE_ MSG (Parent) | RANGE (ILM_DT,F1_REMOTE_MSG_ID) | RANGE(F1_REMOTE_MSG_ID) | F1_REMOTE_MSG.CRE_DTTM | |||
| F1T735P0 | F1_REMOTE_MSG _ID | Global Partitioned  | ||||
| F1T735S1 | CRE_DTTM | Global | ||||
| F1T735S2 | F1_MDT_ID | Global | ||||
| F1T735S3 | MAINT_OBJ_CD | Global | ||||
| F1T735S4 | PK_VALUE1 | Global | ||||
| F1T735S5 | F1_DEVICE_MSG_ID | Global | ||||
| F1T735S6 | F1_MDT_ID, F1_MSG_CLASS_ FLG, F1_DELIVERY_ STATE_FLG | Global | ||||
| CM_ILM_ F1T735S7 | ILM_DT, ILM_ARCH_SW, F1_REMOTE_MSG_ID  | Local Partitioned  | ||||
| F1_REMOTE_MSG_CHAR | Reference Partitioning  | F1T736P0 | F1_REMOTE_MSG_ID, CHAR_TYPE_CD, SEQ_NUM | Global Partitioned  | ||
| F1T736S1 | SRCH_CHAR_VAL | Global | ||||
| F1_REMOTE_ MSG_LOG | Reference Partitioning | F1T737P0 | F1_REMOTE_MSG_ID, SEQNO | Global Partitioned | ||
| F1T737S1 | CHAR_TYPE_CD, CHAR_VAL_FK1  | Global | ||||
| F1T737S2 | CHAR_TYPE_CD, CHAR_VAL  | Global | ||||
| F1_REMOTE_ MSG_LOG_ PARM | Reference Partitioning | F1T738P0 | F1_REMOTE_MSG_ID,  SEQNO, PARM_SEQ | Global Partitioned |
| F1_STATS_ SNPSHT( Parent) | RANGE (ILM_DT, SNAPSHOT_ID) | RANGE (SNAPSHOT_ID) | F1_STATS_ SNPSHT. CRE_DTTM | |||
| F1C706P0 | SNAPSHOT_ID | Global Partitioned | ||||
| F1C706S1 | BUS_OBJ_CD, BO_STATUS_CD, SNAPSHOT_ID | Global | ||||
| CM_ILM_ F1C706S2 | ILM_DT, ILM_ARCH_SW, SNAPSHOT_ID | Local Partitioned | ||||
| F1_STATS_ SNPSHT_CHAR | Reference Partitioning | F1C707P0 | SNAPSHOT_ID, CHAR_TYPE_CD, SEQ_NUM | Global Partitioned | ||
| F1C707S1 | SRCH_CHAR_VAL | Global | ||||
| F1_STATS_ SNPSHT_LOG | Reference Partitioning | F1C708P0 | SNAPSHOT_ID, SEQNO | Global Partitioned | ||
| F1C708S1 | CHAR_TYPE_CD, CHAR_VAL_FK1 | Global | ||||
| F1C708S2 | SNAPSHOT_ID, SEQNO, PARM_SEQ | Global Partitioned | ||||
| F1_STATS_ SNPSHT_REL_ OBJ | Reference Partitioning | F1C710P0 | SNAPSHOT_ID, STATS_SNPSHT_ REL_OBJ_TYPE_ FLG, SEQ_NUM | Global Partitioned |
| F1_ERASURE_SCHED (Parent) | RANGE (ILM_DT, ERASURE_SCHED_ID)  | F1_ERASURE_ SCHED.STATUS_UPD_DTTM | ||||
| F1T756P0 | ERASURE_SCHED_ID | GLOBAL Partitioned  | RANGE (ERASURE_SCHED_ID)  | |||
| CM_ILM_ F1T756S1 | ILM_DT, ILM_ARCH_SW, ERASURE_SCHED_ID  | LOCAL Partitioned | ||||
| F1_ERASURE_SCHED_LOG | Reference partitioning  | F1T757P0 | ERASURE_SCHED_ID,  SEQNO  | GLOBAL Partitioned  | ||
| F1_ERASURE_SCHED_LOG_PARM | Reference partitioning  | F1T758P0 | ERASURE_SCHED_ID,  SEQNO, PARM_SEQ | GLOBAL Partitioned |
| F1_PROC_STORE (Parent) | RANGE(ILM_ DT, PROC_ STORE_ID) | F1_PROC_STORE.STATUS_UPD_DTTM | ||||
| F1T747P0 | PROC_STORE_ID | GLOBAL Partitioned | RANGE(PROC_ STORE_ID) | |||
| CM_ILM_ F1T747S1 | ILM_DT, ILM_ARCH_SW, PROC_STORE_ID | LOCAL Partitioned | ||||
| F1_PROC_STORE_DTL_ELEMENTS | Reference partitioning  | F1T748P0 | PROC_STORE_ID, CHAR_TYPE_CD, SEQ_NUM | GLOBAL Partitioned  | ||
| F1_PROC_ STORE_LOG | Reference partitioning | F1T749P0 | PROC_STORE_ID, SEQNO | GLOBAL Partitioned | ||
| F1_PROC_STORE_LOG_PARM | Reference partitioning | F1T750P0 | PROC_STORE_ID SEQNO, PARM_SEQ | GLOBAL Partitioned |
| D1_ACTIVITY (Parent) | RANGE (ILM_DT, D1_ACTIVITY_ID) Note: Default is to use sub-retention or use RANGE (ILM_DT, D1_ACTIVITY_ID) if not using sub-retention. | D1_ACTIVITY. CRE_DTTM | ||||
| D1T319P0 | D1_ACTIVITY_ID | Global  Partitioned | RANGE  (D1_ACTIVITY_ID) | |||
| D1T319S0 | BUS_OBJ_CD,  BO_STATUS_CD, D1_ACTIVITY_ID | Global  Partitioned | HASH(BUS_OBJ_CD, BO_STATUS_CD, D1_ACTIVITY_ID) | |||
| CM_ILM_D1T319S1 | ILM_DT,  ILM_ARCH_SW, D1_ACTIVITY_ID | Local Partitioned | ||||
| D1_ACTIVITY_ CHAR | REFERENCE (D1_ACTIVITY_ CHAR_FK) | |||||
| D1T320P0 | D1_ACTIVITY_ID, CHAR_TYPE_CD, SEQ_NUM | Global  Partitioned | RANGE(D1_ ACTIVITY_ID) | |||
| D1T320S0 | SRCH_CHAR_VAL | Global  Partitioned | HASH(SRCH_CHAR_VAL) | |||
| D1_ACTIVITY_ IDENTIFIER | REFERENCE (D1_ACTIVITY_IDENTIFIER_FK) | |||||
| D1T330P0 | D1_ACTIVITY_ID, ACTIVITY_ID_TYPE_ FLG | Global  Partitioned | RANGE(D1_ ACTIVITY_ID) | |||
| D1T330S0 | ACTIVITY_ID_TYPE_ FLG, ID_VALUE | Global  Partitioned | HASH(ACTIVITY_ID_TYPE_FLG, ID_VALUE) | |||
| D1T330S1 | ACTIVITY_ID_TYPE_FLG, UPPER(ID_VALUE) | |||||
| D1_ACTIVITY_ LOG | REFERENCE (D1_ACTIVITY_ LOG_FK) | |||||
| D1T321P0 | D1_ACTIVITY_ID, SEQNO | Global  Partitioned | RANGE(D1_ ACTIVITY_ID) | |||
| D1T321S1 | CHAR_TYPE_CD, CHAR_VAL_FK1 | Global  Partitioned | HASH(CHAR_TYPE_CD, CHAR_VAL_FK1) | |||
| D1T321S2 | CHAR_TYPE_CD, CHAR_VAL | Global  Partitioned | HASH(CHAR_TYPE_CD, CHAR_VAL) | |||
| D1_ACTIVITY_ LOG_PARM | REFERENCE (D1_ACTIVITY_ LOG_PARM_FK) | |||||
| D1T322P0 | D1_ACTIVITY_ID, SEQNO PARM_SEQ | Global  Partitioned | RANGE(D1_ ACTIVITY_ID) | |||
| D1_ACTIVITY_ REL | REFERENCE (D1_ACTIVITY_ REL_FK) | |||||
| D1T323P0 | D1_ACTIVITY_ID, ACTIVITY_REL_TYPE_ FLG | Global  Partitioned | RANGE(D1_ ACTIVITY_ID) | |||
| D1T323S0 | REL_ACTIVITY_ID | Global  Partitioned | HASH(REL_ ACTIVITY_ID) | |||
| D1_ACTIVITY_ REL_OBJ | REFERENCE (D1_ACTIVITY_ REL_OBJ_FK) | |||||
| D1T324P0 | D1_ACTIVITY_ID, MAINT_OBJ_CD, ACTIVITY_REL_OBJ_ TYPE_FLG | Global  Partitioned | RANGE(D1_ ACTIVITY_ID) | |||
| D1T324S0 | PK_VALUE1, PK_VALUE2, PK_VALUE3, PK_VALUE4, PK_VALUE5, MAINT_OBJ_CD | Global  Partitioned | HASH(PK_VALUE1,PK_VALUE2, PK_VALUE3, PK_VALUE4) |
| D1_COMM_IN (Parent) | RANGE(ILM_DT, D1_COMM_ID) | D1_COMM_IN. CRE_DTTM | ||||
| D1T386P0 | D1_COMM_ID | Global  Partitioned | RANGE (D1_COMM_ID) | |||
| D1T386S1 | BUS_OBJ_CD, BO_STATUS_CD, D1_COMM_ID | Global  Partitioned | HASH(BUS_OBJ_CD,  BO_STATUS_CD, D1_COMM_ID) | |||
| CM_ILM_D1T386S1 | ILM_DT,  ILM_ARCH_SW, D1_COMM_ID | Local Partitioned | ||||
| D1_COMM_IN_ CHAR | REFERENCE (D1_COMM_IN_ CHAR_FK) | |||||
| D1T387P0 | D1_COMM_ID, CHAR_TYPE_CD, SEQ_NUM | Global  Partitioned | RANGE (D1_COMM_ID) | |||
| D1T387S0 | SRCH_CHAR_VAL | Global  Partitioned | HASH(SRCH_CHAR_VAL) | |||
| D1_COMM_IN_ IDENTIFIER | REFERENCE (D1_COMM_IN_ IDENTIFIER_FK) | |||||
| D1T391P0 | D1_COMM_ID, COMM_ID_TYPE_FLG | Global  Partitioned | RANGE(D1_COMM_ID) | |||
| D1T391S0 | COMM_ID_TYPE_FLG, ID_VALUE | Global  Partitioned | HASH(COMM_ID_TYPE_FLG, ID_VALUE) | |||
| D1T391S1 | COMM_ID_TYPE_FLG, UPPER(ID_VALUE) | |||||
| D1_COMM_IN_ LOG | REFERENCE (D1_COMM_IN_ LOG_FK) | |||||
| D1T388P0 | D1_COMM_ID, SEQNO | Global  Partitioned | RANGE(D1_COMM_ID) | |||
| D1T388S1 | CHAR_TYPE_CD, CHAR_VAL_FK1 | Global  Partitioned | HASH(CHAR_ TYPE_CD, CHAR_VAL_FK1) | |||
| D1T388S2 | CHAR_TYPE_CD, CHAR_VAL | Global  Partitioned | HASH(CHAR_ TYPE_CD, CHAR_VAL) | |||
| D1_COMM_IN_ LOG_PARM | REFERENCE (D1_COMM_IN_ LOG_PARM_FK) | |||||
| D1T389P0 | D1_COMM_ID, SEQNO PARM_SEQ | Global  Partitioned | RANGE(D1_COMM_ID) | |||
| D1_COMM_IN_ REL_OBJ | REFERENCE (D1_COMM_IN_ REL_OBJ_FK) | |||||
| D1T390P0 | D1_COMM_ID, MAINT_OBJ_CD, COMM_REL_OBJ_TYPE_FLG | Global  Partitioned | RANGE(D1_COMM_ID) | |||
| D1T390S0 | PK_VALUE1, PK_VALUE2, PK_VALUE3, PK_VALUE4, PK_VALUE5, MAINT_OBJ_CD | Global  Partitioned | HASH(PK_VALUE1, PK_VALUE2, PK_VALUE3, PK_VALUE4) |
| D1_COMM_OUT (Parent) | RANGE(ILM_DT,D1_COMM_ID) | D1_COMM_ OUT. CRE_DTTM | ||||
| D1T380P0 | D1_COMM_ID | Global  Partitioned | RANGE (D1_COMM_ID) | |||
| D1T380S1 | BUS_OBJ_CD, BO_STATUS_CD, D1_COMM_ID | Global  Partitioned | HASH(BUS_OBJ_CD,  BO_STATUS_CD, D1_COMM_ID) | |||
| CM_ILM_D1T380S1 | ILM_DT,  ILM_ARCH_SW, D1_COMM_ID | Local Partitioned | ||||
| D1_COMM_OUT_CHAR | REFERENCE (D1_COMM_OUT_CHAR_FK) | |||||
| D1T381P0 | D1_COMM_ID, CHAR_TYPE_CD, SEQ_NUM | Global  Partitioned | RANGE (D1_COMM_ID) | |||
| D1T381S0 | SRCH_CHAR_VAL | Global  Partitioned | HASH(SRCH_CHAR_VAL) | |||
| D1_COMM_OUT_IDENTIFIER | REFERENCE (D1_COMM_OUT_IDENTIFIER_ FK) | |||||
| D1T385P0 | D1_COMM_ID, COMM_ID_TYPE_FLG | Global  Partitioned | RANGE(D1_COMM_ID) | |||
| D1T385S0 | COMM_ID_TYPE_FLG, ID_VALUE | Global  Partitioned | HASH(COMM_ID_TYPE_FLG, ID_VALUE) | |||
| D1T385S1 | COMM_ID_TYPE_FLG, UPPER(ID_VALUE) | |||||
| D1_COMM_ OUT_LOG | REFERENCE (D1_COMM_OUT_LOG_FK) | |||||
| D1T382P0 | D1_COMM_ID, SEQNO | Global  Partitioned | RANGE(D1_COMM_ID) | |||
| D1T382S1 | CHAR_TYPE_CD, CHAR_VAL_FK1 | Global  Partitioned | HASH(CHAR_ TYPE_CD, CHAR_VAL_FK1) | |||
| D1T382S2 | CHAR_TYPE_CD, CHAR_VAL | Global  Partitioned | HASH(CHAR_ TYPE_CD, CHAR_VAL) | |||
| D1_COMM_OUT_LOG_PARM | REFERENCE (D1_COMM_OUT_LOG_PARM_FK) | |||||
| D1T383P0 | D1_COMM_ID, SEQNO PARM_SEQ | Global  Partitioned | RANGE(D1_COMM_ID) | |||
| D1_COMM_OUT_REL_OBJ | REFERENCE (D1_COMM_OUT_REL_OBJ_FK) | |||||
| D1T384P0 | D1_COMM_ID, MAINT_OBJ_CD, COMM_REL_OBJ_TYPE_FLG | Global  Partitioned | RANGE(D1_COMM_ID) | |||
| D1T384S0 | PK_VALUE1, PK_VALUE2, PK_VALUE3, PK_VALUE4, PK_VALUE5, MAINT_OBJ_CD | Global  Partitioned | HASH(PK_VALUE1, PK_VALUE2, PK_VALUE3, PK_VALUE4) |
| D1_DVC_EVT (Parent) | RANGE(ILM_DT, DVC_EVT_ID) Note: Default is to use sub-retention or use RANGE (ILM_DT,DVC_EVT_ID) if not using sub-retention. | D1_DVC_EVT. CRE_DTTM | ||||
| D1T400P0 | DVC_EVT_ID | Global  Partitioned | RANGE (DVC_EVT_ID) | |||
| D1T400S1 | BUS_OBJ_CD, BO_STATUS_CD, DVC_EVT_ID | Global  Partitioned | HASH(BUS_OBJ_CD, BO_STATUS_CD, DVC_EVT_ID) | |||
| D1T400S2 | D1_DEVICE_ID, DVC_EVT_DTTM | Global  Partitioned | HASH(D1_DEVICE_ID, DVC_EVT_DTTM) | |||
| D1T400S3 | BUS_OBJ_CD, BO_STATUS_CD, D1_DEVICE_ID, DVC_EVT_ID | Global  Partitioned | HASH(BUS_OBJ_CD, BO_STATUS_CD, D1_DEVICE_ID, DVC_EVT_ID) | |||
| CM_ILM_D1T400S4 | ILM_DT,  ILM_ARCH_SW, DVC_EVT_ID | Local Partitioned | ||||
| D1_DVC_EVT_ CHAR | REFERENCE (D1_DVC_EVT_ CHAR_FK) | |||||
| D1T401P0 | DVC_EVT_ID, CHAR_TYPE_CD, SEQ_NUM | Global  Partitioned | RANGE(DVC_EVT_ID) | |||
| D1T401S0 | SRCH_CHAR_VAL | Global  Partitioned | HASH(SRCH_CHAR_VAL) | |||
| D1_DVC_EVT_ IDENTIFIER | REFERENCE (D1_DVC_EVT_ IDENTIFIER_FK) | |||||
| D1T405P0 | DVC_EVT_ID, DVC_EVT_ID_TYPE_FLG | Global  Partitioned | RANGE(DVC_EVT_ID) | |||
| D1T405S0 | DVC_EVT_ID_TYPE_FLG, ID_VALUE | Global  Partitioned | HASH(DVC_EVT_ID_TYPE_FLG, ID_VALUE) | |||
| D1T405S1 | DVC_EVT_ID_TYPE_FLG, UPPER(ID_VALUE) | |||||
| D1_DVC_EVT_ LOG | REFERENCE (D1_DVC_EVT_ LOG_FK) | |||||
| D1T402P0 | DVC_EVT_ID, SEQNO | Global  Partitioned | RANGE(DVC_EVT_ID) | |||
| D1T402S1 | CHAR_TYPE_CD, CHAR_VAL_FK1 | Global  Partitioned | HASH(CHAR_ TYPE_CD, CHAR_VAL_FK1) | |||
| D1T402S2 | CHAR_TYPE_CD, CHAR_VAL | Global  Partitioned | HASH(CHAR_ TYPE_CD, CHAR_VAL) | |||
| D1_DVC_EVT_ LOG_PARM | REFERENCE (D1_DVC_EVT_ LOG_PARM_FK) | |||||
| D1T403P0 | DVC_EVT_ID, SEQNO PARM_SEQ | Global  Partitioned | RANGE(DVC_EVT_ID) | |||
| D1_DVC_EVT_ REL_OBJ | REFERENCE (D1_DVC_EVT_ REL_OBJ_FK) | |||||
| D1T404P0 | DVC_EVT_ID, MAINT_OBJ_CD, DVC_EVT_REL_OBJ_TYPE_FLG | Global  Partitioned | RANGE(DVC_EVT_ID) | |||
| D1T404S0 | PK_VALUE1, PK_VALUE2, PK_VALUE3, PK_VALUE4, PK_VALUE5, MAINT_OBJ_CD | Global  Partitioned | HASH(PK_VALUE1, PK_VALUE2, PK_VALUE3, PK_VALUE4) |
| D1_COMPL_EVT (Parent) | RANGE(ILM_DT,COMPL_EVT_ID) | D1_COMPL_ EVT. CRE_DTTM | ||||
| D1T340P0 | COMPL_EVT_ID | Global  Partitioned | RANGE (COMPL_EVT_ID) | |||
| D1T340S0 | D1_ACTIVITY_ID | Global  Partitioned | HASH(D1_ ACTIVITY_ID) | |||
| CM_ILM_D1T340S1 | ILM_DT,  ILM_ARCH_SW, DVC_EVT_ID | Local Partitioned | ||||
| D1_COMPL_EVT_CHAR | REFERENCE (D1_COMPL_ EVT_CHAR_FK) | |||||
| D1T341P0 | COMPL_EVT_ID, CHAR_TYPE_CD, SEQ_NUM | Global  Partitioned | RANGE(COMPL_ EVT_ID) | |||
| D1T341S1 | SRCH_CHAR_VAL | Global  Partitioned | HASH(SRCH_CHAR_VAL) | |||
| D1_COMPL_EVT_LOG | REFERENCE (D1_COMPL_EVT_LOG_FK) | |||||
| D1T342P0 | COMPL_EVT_ID, SEQNO | Global  Partitioned | RANGE(COMPL_ EVT_ID) | |||
| D1T342S1 | CHAR_TYPE_CD, CHAR_VAL_FK1 | Global  Partitioned | HASH(CHAR_ TYPE_CD, CHAR_VAL_FK1) | |||
| D1T342S2 | CHAR_TYPE_CD, CHAR_VAL | Global  Partitioned | HASH(CHAR_ TYPE_CD, CHAR_VAL) | |||
| D1_COMPL_EVT_LOG_PARM | REFERENCE (D1_COMPL_EVT_LOG_PARM_FK) | |||||
| D1T343P0 | COMPL_EVT_ID, SEQNO PARM_SEQ | Global  Partitioned | RANGE(COMPL_ EVT_ID) | |||
| D1_COMPL_EVT_REL_OBJ | REFERENCE (D1_COMPL_EVT_REL_OBJ_FK) | |||||
| D1T344P0 | COMPL_EVT_ID, MAINT_OBJ_CD, COMPL_EVT_REL_OBJ_TYP_FLG | Global  Partitioned | RANGE(COMPL_ EVT_ID) | |||
| D1T344S0 | PK_VALUE1, PK_VALUE2, PK_VALUE3, PK_VALUE4, PK_VALUE5, MAINT_OBJ_CD | Global  Partitioned | HASH(PK_VALUE1, PK_VALUE2, PK_VALUE3, PK_VALUE4) |
| D1_INIT_MSRMT_DATA (Parent) | RANGE (ILM_DT,MEASR_COMP_ID) Note: Default is to use sub-retention or use RANGE (ILM_DT,MEASR_COMP_ID) if not using sub-retention. | D1_INIT_MSRMT_DATA. CRE_DTTM | ||||
| D1T304P0 | INIT_MSRMT_DATA_ID | Global  Partitioned | RANGE (INIT_MSRMT_DATA_ID) | |||
| D1T304S1 | MEASR_COMP_ID, D1_TO_DTTM | Global Partitioned | RANGE (MEASR_COMP_ ID) | |||
| CM_ILM_D1T304S4 | ILM_DT,  ILM_ARCH_SW, INIT_MSRMT_DATA_ID | Local Partitioned | ||||
| D1_INIT_MSRMT_DATA_CHAR | REFERENCE (D1_INIT_MSRMT_DATA_CHAR_FK) | |||||
| D1T305P0 | INIT_MSRMT_DATA_ID, CHAR_TYPE_CD, SEQ_NUM | Global  Partitioned | RANGE(INIT_MSRMT_DATA_ID) | |||
| D1T305S1 | SRCH_CHAR_VAL | Global  Partitioned | HASH(SRCH_CHAR_VAL) | |||
| D1_INIT_MSRMT_DATA_LOG | REFERENCE (D1_INIT_MSRMT_DATA_LOG_FK) | |||||
| D1T306P0 | INIT_MSRMT_DATA_ID, SEQNO | Global  Partitioned | RANGE (INIT_MSRMT_DATA_ID) | |||
| D1_INIT_MSRMT_DATA_LOG_ PARM | REFERENCE (D1_INIT_MSRMT_DATA_LOG_PARM_FK) | |||||
| D1T307P0 | INIT_MSRMT_DATA_ID, SEQNO PARM_SEQ | Global  Partitioned | RANGE (INIT_MSRMT_DATA_ID) |
| D1_USAGE (Parent) | RANGE(ILM_DT, D1_USAGE_ID) | D1_USAGE. CRE_DTTM | ||||
| D1T281P0 | D1_USAGE_ID | Global  Partitioned | RANGE (D1_USAGE_ID) | |||
| D1T281S0 | US_ID, START_DTTM | Global  Partitioned | RANGE (US_ID) | |||
| D1T281S1 | BUS_OBJ_CD, BO_STATUS_CD, D1_USAGE_ID | Global  Partitioned | HASH(BUS_OBJ_ CD, BO_STATUS_CD, D1_USAGE_ID) | |||
| CM_ILM_D1T281S2 | ILM_DT, ILM_ARCH_SW, D1_USAGE_ID | Local Partitioned | ||||
| D1T419S1 | USG_EXT_ID, D1_USAGE_ID | Global  Partitioned | RANGE (USG_EXT_ID) | |||
| D1_USAGE_ CHAR | REFERENCE (D1_USAGE_ CHAR_FK) | |||||
| D1T285P0 | D1_USAGE_ID, CHAR_TYPE_CD, SEQ_NUM | Global  Partitioned | RANGE(D1_ USAGE_ID) | |||
| D1T285S1 | SRCH_CHAR_VAL | Global  Partitioned | HASH(SRCH_CHAR_VAL) | |||
| D1_USAGE_LOG | REFERENCE (D1_USAGE_LOG_FK) | |||||
| D1T286P0 | D1_USAGE_ID, SEQNO | Global  Partitioned | RANGE(D1_USAGE_ID) | |||
| D1T286S1 | CHAR_TYPE_CD, CHAR_VAL_FK1 | Global  Partitioned | HASH(CHAR_ TYPE_CD, CHAR_VAL_FK1) | |||
| D1T286S2 | CHAR_TYPE_CD, CHAR_VAL | Global  Partitioned | HASH(CHAR_ TYPE_CD, CHAR_VAL) | |||
| D1_USAGE_LOG_PARM | REFERENCE(D1_USAGE_LOG_ PARM_FK) | |||||
| D1T287P0 | D1_USAGE_ID, SEQNO PARM_SEQ | Global  Partitioned | RANGE (D1_USAGE_ID) | |||
| D1_USAGE_ PERIOD | REFERENCE(D1_USAGE_PERIOD_FK) | |||||
| D1T283P0 | D1_USAGE_ID, PERIOD_SEQ_NUM | Global  Partitioned | RANGE(D1_ USAGE_ID) | |||
| D1_USAGE_ PERIOD_ITEM_DET | REFERENCE(D1_USAGE_PERIOD_ITEM_DET_FK) | |||||
| D1T431P0 | D1_USAGE_ID, PERIOD_SEQ_NUM, ITEM_SEQ_NUM | Global  Partitioned | RANGE(D1_USAGE_ID) | |||
| D1_USAGE_ PERIOD_SQ | REFERENCE(D1_USAGE_PERIOD_SQ_FK) | |||||
| D1T284P0 | D1_USAGE_ID, PERIOD_SEQ_NUM, SQ_SEQ_NUM | Global  Partitioned | RANGE(D1_ USAGE_ID) | |||
| D1_USAGE_PERIOD_SQ_DATA | REFERENCE(D1_USAGE_PERIOD_SQ_DATA_FK) | |||||
| D1T497P0 | D1_USAGE_ID, PERIOD_SEQ_NUM, SQ_SEQ_NUM, SQ_DATA_DTTM | Global Partitioned  | RANGE(D1_ USAGE_ID) | |||
| D1_USAGE_REL | REFERENCE (D1_USAGE_REL_FK) | |||||
| D1T316P0 | D1_USAGE_ID, USAGE_REL_TYPE_FLG | Global  Partitioned | RANGE(D1_ USAGE_ID) | |||
| D1T316S0 | REL_USAGE_ID, USAGE_REL_TYPE_FLG, D1_USAGE_ID | Global  Partitioned | HASH(REL_USAGE_ID, USAGE_REL_TYPE_FLG, D1_USAGE_ID) | |||
| D1_USAGE_ SCALAR_DTL | REFERENCE(D1_USAGE_SCALAR_DTL_FK) | |||||
| D1T282P0 | D1_USAGE_ID, D1_SP_ID, SEQ_NUM | Global  Partitioned | RANGE(D1_ USAGE_ID) |
| D1_USAGE_ EXCP (Parent) | RANGE (ILM_DT, USAGE_EXCP_ ID) | D1_USAGE_ EXCP. CRE_DTTM | ||||
| D1T443P0 | USAGE_EXCP_ID | Global Partitioned | RANGE (USAGE_EXCP_ ID) | |||
| CM_ILM_D1T443S1 | ILM_DT, ILM_ARCH_SW, USAGE_EXCP_ID | Local Partitioned | ||||
| D1_USAGE_ EXCP_CHAR | REFERENCE (D1_USAGE_ EXCP_CHAR_ FK) | D1T446P0 | USAGE_EXCP_ID, CHAR_TYPE_CD, SEQ_NUM | Global Partitioned | RANGE (USAGE_EXCP_ ID) | |
| D1T446S1 | SRCH_CHAR_VAL | Global Partitioned | HASH (SRCH_CHAR_ VAL) | |||
| D1_USAGE_ EXCP_PARM | REFERENCE (D1_USAGE_ EXCP_PARM_ FK) | D1T445P0 | USAGE_EXCP_ID, PARM_SEQ | Global Partitioned | RANGE (USAGE_EXCP_ ID) |
| D1_VEE_EXCP (Parent) | RANGE(ILM_DT, VEE_EXCP_ID) | D1_VEE_EXCP. CRE_DTTM | ||||
| D1T308P0 | VEE_EXCP_ID | Global  Partitioned | RANGE (VEE_EXCP_ID) | |||
| D1T308S1 | INIT_MSRMT_DATA_ID | Global  Partitioned | HASH(INIT_ MSRMT_DATA_ID) | |||
| CM_ILM_D1T308S2 | ILM_DT, ILM_ARCH_SW, VEE_EXCP_ID | Local Partitioned | ||||
| D1_VEE_EXCP_CHAR | REFERENCE (D1_VEE_EXCP_ CHAR_FK) | |||||
| D1T310P0 | VEE_EXCP_ID, CHAR_TYPE_CD, SEQ_NUM | Global  Partitioned | RANGE(VEE_ EXCP_ID) | |||
| D1T310S1 | SRCH_CHAR_VAL | Global  Partitioned | HASH(SRCH_CHAR_VAL) | |||
| D1_VEE_EXCP_PARM | REFERENCE (D1_VEE_EXCP_ PARM_FK) | |||||
| D1T309P0 | VEE_EXCP_ID, PARM_SEQ | Global  Partitioned | RANGE(VEE_ EXCP_ID)) |
| D1_ACTIVITY (Parent) | RANGE (ILM_DT, RETENTION_ PERIOD) | D1_ACTIVITY. CRE_DTTM | ||||
| CM_ILM_D1T319S1 | ILM_DT,  RETENTION_PERIOD, ILM_ARCH_SW, D1_ACTIVITY_ID | Local Partitioned | ||||
| D1_DVC_EVT (Parent) | RANGE(ILM_DT, RETENTION_ PERIOD) | D1_DVC_EVT. CRE_DTTM | ||||
| CM_ILM_D1T400S4 | ILM_DT,  RETENTION_PERIOD, ILM_ARCH_SW, DVC_EVT_ID | Local Partitioned | ||||
| D1_INIT_MSRMT_DATA (Parent) | RANGE (ILM_DT, RETENTION_ PERIOD) | D1_INIT_MSRMT_DATA. CRE_DTTM | ||||
| D1T304P0 | INIT_MSRMT_DATA_ID | Global  Partitioned | RANGE (INIT_MSRMT_ DATA_ID) | |||
| CM_ILM_D1T304S4 | ILM_DT,  RETENTION_PERIOD, ILM_ARCH_SW, INIT_MSRMT_DATA_ID | Local Partitioned | ||||
| D1_INIT_MSRMT_SNAP (Parent) | Range(ILM_DT, INIT_MSRMT_ SNAP_ID) | D1T622P0 | INIT_MSRMT_SNAP_ID | Global Partitioned | Range(INIT_ MSRMT_SNAP_ID) | D1_INIT_MSRMT_SNAP.CRE_ DTTM |
| CM_ILM_D1T622L0 | ILM_DT,  ILM_ARCH_SW, INIT_MSRMT_SNAP_ID | Local Partitioned | ||||
| D1_INIT_MSRMT_SNAP_CHAR | Reference Partitioning | D1T624P0 | INIT_MSRMT_SNAP_ID,  CHAR_TYPE_CD,  SEQ_NUM | Global Partitioned | ||
| D1_INIT_MSRMT_SNAP _LOG | Reference Partitioning | D1T625P0 | INIT_MSRMT_SNAP_ID,  SEQNO | Global Partitioned | ||
| D1_INIT_MSRMT_SNAP _LOG_PARM | Reference Partitioning | D1T626P0 | INIT_MSRMT_SNAP_ID,  SEQNO,  PARM_SEQ | Global Partitioned |
| D1_MDSI (Parent) | Range(ILM_DT, D1_MDSI_ID) | D1T565P0 | D1_MDSI_ID | Global Partitioned | Range(D1_MDSI_ ID) | D1_MDSI_ START_DTTM |
| CM_ILM_D1T565L0 | ILM_DT,  ILM_ARCH_SW, D1_MDSI_ID | Local Partitioned |
| D1_MDSS (Parent) | Range(ILM_DT, D1_MDSS_ID) | D1T594P0 | D1_MDSS_ID | Global Partitioned | Range(D1_MDSS_ID | D1_MDSS_ START_DTTM |
| CM_ILM_D1T594L0  | ILM_DT,  ILM_ARCH_SW, D1_MDSS_ID | Local Partitioned |
| D1_SP_SNAP_DL | RANGE(ILM_DT, SP_SNAP_ID) | D1_SP_SNAP_DL.SNAPSHOT_DTTM | ||||
| D1T434P0 | SP_SNAP_ID | Global Partitioned | RANGE(SP_SNAP_ID) | |||
| D1T434S0 | D1_SP_ID, SNAPSHOT_DTTM, SNAPSHOT_TYPE_FLG | Global Partitioned	 | ||||
| D1T434S1 | CM_ILM_ILM_DT, ILM_ARCH_SW, SP_SNAP_ID | Local Partitioned | ||||
| D1_SP_UNR_ USG_SNAP_DL | RANGE(ILM_DT, SP_UNR_USG_ SNAP_ID) | D1_SP_UNR_USG_SNAP_DL.SNAPSHOT_DTTM | ||||
| D1T438P0 | SP_UNR_USG_SNAP_ID | Global Partitioned | RANGE(SP_UNR_USG_SNAP_ID) | |||
| D1T438S0 | D1_SP_ID, SNAPSHOT_DTTM, UNR_USG_SNAPSHOT_ TYPE_FLG, SNAPSHOT_TYPE_FLG | Global Partitioned | ||||
| CM_ILM_D1T438S1 | ILM_DT, ILM_ARCH_SW, SP_UNR_USG_SNAP_ID | Local Partitioned | ||||
| D1_SP_USG_ SNAP_DL | D1_SP_USG_ SNAP_DL | D1_SP_USG_SN AP_DL.SNAPSH OT_DTTM | ||||
| D1T436P0 | SP_USG_SNAP_ID | Global Partitioned | RANGE(SP_USG_ SNAP_ID) | |||
| D1T436S0 | D1_SP_ID, SNAPSHOT_DTTM, MEASR_COMP_ID, USG_SNAPSHOT_TYPE_FLG, D1_TOU_CD, MSRMT_COND_FLG, SNAPSHOT_TYPE_FLG | Global | ||||
| CM_ILM_D1T436S1 | ILM_DT, ILM_ARCH_SW, SP_USG_SNAP_ID | Local Partitioned | ||||
| D1_SP_VEE_EXCP_SNAP_DL | RANGE(ILM_DT, SP_VEE_EXCP_ SNAP_ID) | D1_SP_VEE_ EXCP_SNAP_ DL.SNAPSHOT_ DTTM | ||||
| D1T440P0 | SP_VEE_EXCP_SNAP_ID | Global Partitioned | RANGE(SP_VEE_EXCP_SNAP_ID) | |||
| D1T440S0 | D1_SP_ID, SNAPSHOT_DTTM, MEASR_COMP_ID, EXCP_TYPE_CD, D1_IMD_TYPE_FLG, EXCP_SEVERITY_FLG, VEE_GRP_CD, VEE_RULE_CD, SNAPSHOT_TYPE_FLG | |||||
| CM_ILM_ D1T440S1 | ILM_DT, ILM_ARCH_SW, SP_VEE_EXCP_SNAP_ID | Local Partitioned |
