Feature Configuration - Main
To define your feature configuration, open
Use the Feature Configuration Query portal to search for an existing feature configuration. Once a feature configuration is selected, you are brought to the maintenance portal to view and maintain the selected record.
Description of Page
Enter an easily recognizable Feature Name code.
Indicate the Feature Type for this configuration. For example, if you were setting up the options for the external messages, you'd select External Messages.
You can add new Feature Types. Refer to the description
of the page above for how you can add Feature Types to control features
developed for your implementation.
Multiple Feature Configurations for a Feature Type.
Some Feature Types allow multiple feature configurations. The administration
documentation for each feature will tell you when this is possible.
The Options grid allows you to configure the feature. To do this, select the Option Type and define its Value. Set the Sequence to 1 unless the option may have more than value. Detailed Description may display additional information on the option type.
Each option is documented elsewhere. The administration
documentation for each feature describes its options and whether an
option supports multiple values. Use the index to look for ‘feature
configuration’ to find the various types of feature options.
You can add new options to base-package features. Your
implementation may want to add additional options to one of the base-package's
feature types. For example, your implementation may have plug-in driven
logic that would benefit from a new option. To do this, display the
lookup field that holds the desired feature's options. The lookup
field's name is xxxx_OPT_TYP_FLG where xxxx is the
identifier of the feature on the EXT_SYS_TYP_FLG lookup value. For example, to add new
batch scheduler options, display the lookup field BS_OPT_TYP_FLG.
