Captured Information
When auditing is enabled for a field, the following information is recorded when the field is changed, added and/or deleted (depending on the actions that you are auditing for that field):
- User ID
 - Date and time
 - Table name
 - Row's prime key value
 - Field name
 - Before image (blank when a row is added)
 - After image (blank when a row is deleted)
 - Row action (add, change, delete)
