Defining Asset Location Types
The Asset Location Type portal is used to display and maintain asset location types.
You can access this portal from Admin, select A, and then select Asset Location Type.
The following zones may appear as part of the portal’s Main tab page.
  • Asset Location Type List: This zone lists all the asset location types. Broadcast a record to display the details for the selected record.
  • Asset Location Type: This zone provides information about the selected asset location type, including valid breaker location types and valid runtime source location types information.
