Maintaining Financial Transactions
The Financial Transaction portal is used to display and maintain financial transaction records.
You can access the portal from Menu, select Financial, then select Financial Transaction. You are brought to a query portal with options for searching for a specific transaction. Once a record has been selected, you are brought to the maintenance portal to view and maintain the selected record.
  • Financial Transaction: This zone display information about the financial transaction such as, currency code, accounting date, GL details, and more.
