Maintaining Invoices
The Invoice portal is used to display and maintain an invoice record.
You can access the portal from Menu, select Purchasing, then select Invoice. You are brought to a query portal with options for searching for a specific record. Once an invoice has been selected, you are brought to the maintenance portal to view and maintain the selected record.
  • Invoice Header: This zone displays information about the invoice, such as payment information, cost allocation, and tax information.
  • Invoice Lines: This zone lists the invoice lines associated with the invoice record.
  • Notes: This zone displays any notes associated with the invoice record.
  • Attachments: This zone enables users to manage all types of attachments for the invoice record.
The following zones may appear as part of the portal’s Financial Transaction tab page:
  • Invoice Header Financial Transaction: This zone lists the financial transactions associated with the invoice record.
