Maintaining Material Request Templates
The Material Request Template portal is used to display and maintain a material request template record.
You can access the portal from Menu, select Inventory, then select Material Request Template. You are brought to a query portal with options for searching for a specific material request template. Once the template has been selected, you are brought to the maintenance portal to view and maintain the selected record.
  • Material Request Template Display: This zone displays information about the selected material request template record.
