Additional Search Options
The product supports fuzzy searching in explorer zone types using the Oracle Text CONTAINS operator.
Refer to the DBA guide for details on setting up the database to support fuzzy searching. Note that there are some implementations where fuzzy searching will not be possible. For example, it's only available for implementations using the Oracle database. Additionally, not all languages are supported. Refer to the Oracle Database documentation for more information about fuzzy searching.
For information about the particular syntax to use in the explorer zones, refer to SQL Statement in the zone parameter details section.
