Understanding Data Export
The application supports the following classes of export methods
for a maintenance object:
Generalized. This method may be used for maintenance objects that are low to medium in volume and update activity. Most maintenance objects are eligible for this method.
Specialized. This method should be used for maintenance objects that are high in volume or very frequently updated.
This section discusses concepts and guidelines related to data export features.
