Favorite Scripts Zone
The Favorite Scripts zone lists the business process assistant (BPA) scripts that you have defined on your user preferences. You can click on a script to execute it. You can click the Search button in the zone to search for other scripts.
Note: If you do not see the Favorite Scripts zone in your dashboard,
navigate to User Menu and click the Preferences menu item to
display the User - Portal Preferences page.
Under the Dashboard Portal row, select the Display option for
the Favorite Scripts zone.
