Creating Application Links in External Applications
When integrating Oracle Utilities applications with other external applications, you can create links from external applications to specific portals and pages within the Oracle Utilities applications (also known as "deep linking"). These links typically leverage Business Process Assistant (BPA) scripts that direct the user to the appropriate target portal or page for a specific entity such as an account or service point. Refer to Creating Application Links in External Applications in the Application Framework Administrative User Guide for more information about creating links.
Note: When creating application links, the use of the following parameters will help speed up launching the target page
  • initNav=false: skips launching the default home page for the user
  • minDashboard=true  minimizes the dashboard for the user
GoTo Portal Script
The Framework provides a generic script (F1-GoToPrtl) that can be used to navigate to the maintenance portal for a specified maintenance object and entity. Refer to Creating Application Links in External Applications in the Application Framework Administrative User Guide for more information about using this script.
WAM Examples
The table below provides examples of using the F1-GoToPrtl script to open specific portals used by Oracle Utilities Work and Asset Management.
Script
MO
ID
Example
F1-GoToPrtl
mo=W1-ACT
Activity ID
&script=F1-GoToPrtl&mo=W1-ACT&pkValue1={your Activity ID}
F1-GoToPrtl
mo=W1-ASSET
Asset ID
&script=F1-GoToPrtl&mo=W1-ASSET&pkValue1={your Asset ID}
F1-GoToPrtl
mo=W1-NODE
Location ID
&script=F1-GoToPrtl&mo=W1-NODE&pkValue1={your Location ID}
F1-GoToPrtl
mo=W1-WORKORDER
Work Order ID
&script=F1-GoToPrtl&mo=W1-WORKORDER&pkValue1={your Work Order ID}
Full URL Example:
https://<ENV_BASE_URL>/ouaf/cis.jsp/?minDashboard=true&initNav=false&script=F1-GoToPrtl&mo=W1-ACT&pkValue1={your Activity ID}
